Help, car won't start.
- JimmytheJimny
28 Nov 2013 13:36 #93586
by JimmytheJimny
Help, car won't start. was created by JimmytheJimny
Hello, I'm Matt, I've recently bought a 2000 Jimny and signed up here to read about other builds and for guidence etc. but I need help from the get go.
The maiden voyage went well, very pleased it, albeit with a few issues, blown bulbs etc. and the Check Engine Light coming on! Still, it drove great, idled fine and pulled well. I got home and fitted new bulbs, but the drivers headlight refused to work. After checking voltages and removing rust on the connector for it still not working, I gave up on it and went on to find why the CEL was on.
I did the usual test by shorting the pins in the connector behind the drivers headlight. Only to find out that the car won't start, there's no power, not even the handbrake-on light. I thought I'd left the headlights on and drained the battery. After a couple of attempts at jump starting it, there's still nothing, it appears dead apart from a little movement in the water temperature gauge. What went wrong, is there anything I can do?
- markyp2000
28 Nov 2013 13:57 #93594
by markyp2000
Replied by markyp2000 on topic Help, car won't start.
You cant test jimnys like that and why would you short it out
Jimnys run a switched earth lighting you should have used a multi meter
Test all the fueses under the dash and the ones next to the battery
Or worst thing you could have done is shorted it out and melted a wire
Alsois it single or twin cam engine does it have a timing/cam belt or a timing chain
- JimmytheJimny
28 Nov 2013 16:45 #93607
by JimmytheJimny
Replied by JimmytheJimny on topic Help, car won't start.
Thanks for the reply,
It's the 16v DOHC, and I had assumed they're all belt, but I could be wrong, so I'm not sure what mine is now.
All fuses under the dash are ok, I've not checked the under bonnet fuses though. Lights have been read with a voltmeter, the side that's not working wasn't getting anything.
"Shortings" probably the wrong term, it's the usual test for reading fault codes, to 'bridge' 2 and 4 on the connection block. Anyway, I don't think that's the problem now, I've just been trying to jump start it again, but left it at high revs for 10minutes and lights came on the dash, but it didn't have the juice to turn over. Going back out to give it another go for longer.
28 Nov 2013 16:48 #93608
by gilburton
Replied by gilburton on topic Help, car won't start.
Duff battery?? Have you checked the battery connections? If it's not that try charging the battery off the vehicle and see if it holds a charge??
- jonesyba420
28 Nov 2013 16:50 #93609
by jonesyba420
Replied by jonesyba420 on topic Help, car won't start.
DOHC is chain driven i believe.
28 Nov 2013 17:29 #93614
Replied by helijohn on topic Help, car won't start.
Is there a master fuse like some cars have?
