Front wheel bearing
  • northeastern
24 Sep 2013 19:01 #84232 by northeastern
Front wheel bearing was created by northeastern
Just doing a pre MOT and found play on off side wheel, using the advice from Martin (foot on brake pedal test) it proved to be the wheel bearing.
The question I ask before doing job, does the locking nut turn clockwise or anti clockwise to undo.
Thanks H
24 Sep 2013 19:35 #84244 by kirkynut
Replied by kirkynut on topic Front wheel bearing
Anti clockwise done up very, very tight! You need the special tool though, don't bugger it up with a chisel.
  • northeastern
24 Sep 2013 20:00 #84253 by northeastern
Replied by northeastern on topic Front wheel bearing
kirkynut wrote: Anti clockwise done up very, very tight! You need the special tool though, don't bugger it up with a chisel.
Thank you,
just reading instruction's it doesn't say and I've known other shafts to be clockwise to tighten ,didn't want to swinging the bar in the wrong direction. :laugh:
Yeah I've got the tool borrowed kindly off Suzuki dealer in Durham.
cheers H
  • markyp2000
25 Sep 2013 17:01 #84354 by markyp2000
Replied by markyp2000 on topic Front wheel bearing
Thank you,
cheers H
All nuts and bolt tighten up clockwise unless other wise stated by th look of the nut some times
  • northeastern
25 Sep 2013 17:20 #84359 by northeastern
markyp2000 wrote:
Thank you,
cheers H
Sorry don't understand what you saying
  • markyp2000
25 Sep 2013 18:09 #84361 by markyp2000
You said
Thank you,just reading instruction's it doesn't say and I've known other shafts to be CLOCKWISE TO TIGHTEN ,didn't want to swinging the bar in the wrong direction. Yeah I've got the tool borrowed kindly off Suzuki dealer in Durham.cheers H
I was comenting on the bit iv changer to UPPER CASE
Time to create page: 0.192 seconds
