jimny 2000 1.3 twin cam down on power
- 410shotgun
20 Sep 2013 19:23 #83804
by 410shotgun
jimny 2000 1.3 twin cam down on power was created by 410shotgun
my jimny is down on power
its a twin cam hard top x reg
its had new plugs / leads and coil packs
by still low power
I think is it the egr valve
any idears
by still low power
any idears
- JuanGuillie
20 Sep 2013 19:52 #83808
by JuanGuillie
Replied by JuanGuillie on topic jimny 2000 1.3 twin cam down on power
Air filter ?
Air intake under the right front wing blocked (maybe some mud, doing some offroading) ?
To control the last one you have to take your inner wheelarch out (some screws and plastic caps have to be loosen).
Fuel pump?
Crankshaft sensor?
Fuel pump?
Crankshaft sensor?
- 410shotgun
20 Sep 2013 21:18 #83819
by 410shotgun
Replied by 410shotgun on topic jimny 2000 1.3 twin cam down on power
also the tick over goes right down after around a mile then goes ok but just no power on hills
I drove a w reg today sohc and it went like the clapers
- gaz3359
20 Sep 2013 22:13 #83825
by gaz3359
Replied by gaz3359 on topic jimny 2000 1.3 twin cam down on power
You had the codes read ?
- 410shotgun
21 Sep 2013 08:37 #83843
by 410shotgun
no I will check it today had a new ecu as the other packed up
- jonesyba420
21 Sep 2013 08:55 #83848
by jonesyba420
Replied by jonesyba420 on topic jimny 2000 1.3 twin cam down on power
Blocked cat or cats, I had a similar problem and it got worse and worse untill I couldnt go above 10 mph! Turned out the cat near the manifold had collapsed blocking the main cat. New cat problem solved. Left the one near the manifold straight through.
Time to create page: 0.303 seconds
