Crankshaft sensor
- Adamski
16 years 2 months ago #4536
by Adamski
Crankshaft sensor was created by Adamski
I discovered an issue with my jimny and having read up on various forums I suspect that my crankshaft sensor needs replacing. can anyone tell me if this is a dealership only part and how much I should expect to pay?
16 years 2 months ago #4538
by facade
Replied by facade on topic Re:Crankshaft sensor
How do you know it is faulty?
You might not even have one, AFAIK only the Spanish built convertibles have one, you don't say which car and engine you have.
The twin cam engine has just the cam sensor, that can be changed very easily it: is at the top front of the engine, right hand side as you face the engine.
You need the fault codes read unless you like gambling with quite a lot of money.
A sensor fault is usually poor running: the engine light comes on on the motorway/stalling when hot, cooling the sensor will allow an immediate restart.
- Adamski
16 years 2 months ago #4539
by Adamski
Replied by Adamski on topic Re:Crankshaft sensor
facade wrote:
that is exactly the fault I have. I think you maybe right about it being the cam sensor if that's the sensor at the front. I think I must have got mixed up and thought that was the Crankshaft sensor. I have a 2002 hardtop jimny special with twin cam. and idea how much a cam sensor will set me back?
thanks,
Adam
thanks,
Adam
- Top Rope Terry
16 years 2 months ago #4542
by Top Rope Terry
Replied by Top Rope Terry on topic Re:Crankshaft sensor
hi well my crankshaft sensor cost round the 60 pound mark don't know if there same but might be a little guide price for ya
16 years 2 months ago - 16 years 2 months ago #4543
Replied by mlines on topic Re:Crankshaft sensor
Its easy to get mixed up as it differs between the engine types and you need to establish which engine you have.
The first engine below is the single overhead cam G13BB engine, fitted to all Jimnys prior to 2001 and to Spanish softop Jimnys as late as 2004. AS you can see it if only fitted with a Camshaft Position Sensor (Number 7 in the picture)
Press the CONTROL key on your keyboard whilst scrolling the wheel on you mouse to zoom in
From 2001 onwards the Jimnys were fitted with an double overhead camshaft M13AA engine (except Spanish Softtops). These have both a Camshaft Sensor (Number 7) and a Crankshaft Sensor (Number 5). This also applies to the later VVT engine from 2005 onwards.
Last edit: 16 years 2 months ago by mlines.
16 years 2 months ago #4544
by facade
I got them backwards :blush:
You likely have both sensors, you need to find out which one to change. If the engine stops altogether, likely it is the cam sensor.
If the crank sensor goes the engine light comes on and it runs in limp home mode.
You can buy an OBD2 fault code reader from eBay for about £20 that will work on a 2002, allow you to find which sensor is faulty and clear the error code.
The reader will work on most petrol cars from 2003, but the Jimny complied with OBD2 in 2000 (Japanese built).
There are cam sensors on eBay for about £35.
