arb with tmax pump
- suzuki jimny fella
04 May 2012 21:20 #39318
by suzuki jimny fella
arb with tmax pump was created by suzuki jimny fella
as above can i use me tmax compesser to run a ARB
- adamjimny
04 May 2012 21:51 #39322
by adamjimny
Replied by adamjimny on topic Re: arb with tmax pump
No
The tmax wont store pressure which the arb needs to operate or it will leak pressure and dissengage
And you cant leave the tmax one on as its not designed to hold pressure
The arb compressore has a tank which stores pressure and only recharges when needed
sent from my Samsung Galaxy S2 using Tapatalk
- Rockwatt
04 May 2012 22:49 #39330
by Rockwatt
Replied by Rockwatt on topic Re: arb with tmax pump
Yes you can ! You will need a presure switch (viair do one for less than £20) and a small tank, one of them small disposable welding gas bottles works great and plenty big enough for a couple of arb's
Just unscrew the valve out the end and put in a fitting, it's 1/8 bsp.
Or if you want to be really cheep you can use a coke bottle (yes really ! It's been proven they take the pressure and if they do get damaged then it doesn't chuck shrapnel at you)
- reaper
04 May 2012 22:55 #39331
by reaper
Replied by reaper on topic Re: arb with tmax pump
You can also use a reciever tank from an old fridge ( not the large black bit thats a compresser its a small tank found on larger fridges )
- Rockwatt
04 May 2012 23:07 #39332
by Rockwatt
There you go a couple of good ideas for a tank and mostly free.
I wouldn't go with the coke bottle though!
I don't know what fitting the fridge reciever would have , I expect it would be a soldered pipe but it will be rated at the pressure needed as would the welding gas bottle.
- reaper
04 May 2012 23:16 - 04 May 2012 23:17 #39333
by reaper
Normally 1/4 so brake pipe fittings would work well
Last edit: 04 May 2012 23:17 by reaper.
Time to create page: 0.226 seconds
