jimny leaning to one side?
- Madge
24 Apr 2012 18:30 #38506
by Madge
jimny leaning to one side? was created by Madge
hi every one i was just wondering if any one could help my jimny is slowly starting to sag down on the left hand side its gt 2inch coil spring lift with rough country shocks and there only a year old everything looks ok apart from the sag was thinking of swapping the right front for the left front to even it out would this work thanks matt
- supergaz
24 Apr 2012 18:44 - 24 Apr 2012 18:45 #38510
by supergaz
Replied by supergaz on topic Re: jimny leaning to one side?
This is common, Known as the jimny lean. Most suspension kits have a longer offside front spring to take the extra weight of that corner of the jimny.
The easy fix is to fit 1 spring spacer to that corner.
www.bits4vits.co.uk/store/jimny/spring-s...y-lean-/prod_43.html
I use 4 of these spacers to compensate for the extra weight of my roll cage on top of my +3 lift springs.
Last edit: 24 Apr 2012 18:45 by supergaz.
- Beano
24 Apr 2012 18:53 #38511
by Beano
Replied by Beano on topic Re: jimny leaning to one side?
This is what it looks like
Mine was leaning too so i bagged me one of these bad boys from bits4vits and fitted it yesterday. £24 and problem solved!
Beano
Beano
- Madge
24 Apr 2012 18:57 #38512
by Madge
Replied by Madge on topic Re: jimny leaning to one side?
hi thanks yer i have a role cage and offroad armoury front winch bumper with winch you think fitting one of these spacers to the front left will work? would i need to get 4 like you have as got all the extra weight thanks matt
- Beano
24 Apr 2012 18:59 #38513
by Beano
Oh, sorry..... :blush:
Technical error! cant submit the attached picture for some reason!
Doh!
Doh!
- Beano
24 Apr 2012 19:01 #38514
by Beano
Attempt two
Time to create page: 0.189 seconds
