Recovery Points
- doncarlyon
Also can anyone recommend any tow ropes, etc? Wont be doing anything extreme, just be handy to have something in the car.
www.suzuki4u.co.uk/forum/viewtopic.php?t=9975
This the only bolt-on lve found.
en.item.rakuten.com/apio/3070_16/
2002 JLX Soft Top
If you search on difflock for "lifechooser" theres a thread on there about the apio ones, he got some via a friend of his that imports jap motors iirc.
The standard ones are ok for a "gentle" pull and definitely no snatch recovery. I use a short strap across the 2 and a 4 metre strap. I've not been stuck for a long time though and only needed any help when i was cross axled(will get it stuck again in the same spot to try left foot braking and see if i can get out). I'd always recommend a bridle to halve the load seen at each point. The points on mine have a small hole at the bottom and a bigger one nearer the chassis i use these as i cant get the shackles through the others, be aware that it will pull against the bumper - especially if you're not pulling perfectly straight.
My straps are from damar(sp) webbing on ebay, i got the short one from them at a show though. Another was acquired from a mate. I'd not use a KERR on the stock points.
Straps are easier to handle and to clean imo. You'll need some shackles too, i use blue pin ones again i think the cheapest i could find them was ebay. I tried local lifting suppliers and everything was a fortune.
Bertie bas on difflock is highly recommended on there for recovery gear.
- VAXXi
Japanese APIO makes some very interesting attachments, but I haven't researched the topic of shipping yet. It looks to be quite expensive anyway, for just a few pieces of metal. Hope these pics give someone the idea of manufacturing them closer to Europe :whistle:
- doncarlyon
- Johnniehec
- Thank you received: 56
VAXXi wrote: The lacking recovery points also worry me, as the tie-down eyelets aren't really that strong. Proof:
VAXXi How on earth did you manage that!!? I'm guessing kinetic recovery.
I have a standard towbar on the back and that's been used on the few occasions I've been recovered backwards, by winch, I wouldn't use it for kinetic though.
doncarlyon, I've used a strop between the standard front eyes, again for winch recovery, wouldn't do kinetic on their either.
I remember an incident many years ago recovering a Trooper with the official Izuzu tow rope, the forged hook on the end of it made a beautiful hole through the rear door of the Ninety as it straightened and let go of the Trooper when the "load" was applied. Recovery is a dangerous excercise.
Cheers,
John.
