Drum brake pad change
- Danparry
06 Jan 2023 10:49 #246716
by Danparry
Drum brake pad change was created by Danparry
HeyIm looking at changing my rear drum brake pads in my 06 jimny, Could I get some tips or a how to guide from someone that's done this? I've done plenty of disc brake pads but never drum brakes, I've got no idea lol it all looks abit scary,, I don't wanna stuff it up,, so ide like as much help as I can before I attempt it.. Thanks.. Dan
- Thank you received: 569
06 Jan 2023 11:35 #246717
Replied by DrRobin on topic Drum brake pad change
I haven't done the job, but there is a detailed 'how to' in the wiki, see below
www.bigjimny.com/mediawiki/index.php/Rea...ke_shoes_replacement
Let us know how it goes as it suggests that you need to replace frequently so I might have to do mine sometime.
Robin
Robin
06 Jan 2023 11:37 - 06 Jan 2023 11:39 #246718
by Scimike
Replied by Scimike on topic Drum brake pad change
Tips
Do one side at a time, that way if it goes wrong you have the untouched side as a reference.
In the day of phones take loads of pictures, before and during, again a look back reference.
Don't be in a rush, take your time
They are just shoes pulled off with springs. Auto adjust / handbrake need backing off or resetting, I'll let someone else comment on these and any other bits. They are on my to do list, so never done Jimny specific but plenty of others.
The last time I looked they didn't need changing and the vehicle was 50K in, so not sure about change frequently unless it's an off road consequence. I don't off road ours.
Last edit: 06 Jan 2023 11:39 by Scimike.
- Thank you received: 1889
06 Jan 2023 12:39 #246721
Replied by Lambert on topic Drum brake pad change
The trick with brake shoes is to put all the springs in place before you put the shoes on the back plate that way you have something to pull the springs apart with instead of fighting with them using screwdriver and pliers.
- Danparry
07 Jan 2023 00:54 - 07 Jan 2023 01:17 #246736
by Danparry
Replied by Danparry on topic Drum brake pad change
Thanks for the tips, I'll give it a go, Also, do I need to loosen the handbrake cable from the nut on the handbrake before,
When changing the pads do i have to.remove the brake cylinder from within the hub? And when it comes to adjusting the brakes once everything is fitted what's the trick there? How do I no if there properly adjusted?
Last edit: 07 Jan 2023 01:17 by Danparry.
07 Jan 2023 04:30 #246737
As long as you are only replacing the shoes all you need to do is make sure you have the hand brake lever off, you don't need to slacken anything else. Once you get the drum off for which there are 2 threaded holes you wind bolts in to push it off the hub you then undo the pins that hold the shoes to the back plate and then pull the shoes apart at the top so you can get them past the retaining slot on the cylinder. I can do this by hand but I'm built like an ox you may need a pry bar. Disconnect the hand brake cable. Then you just swap out the springs between the new shoes and put it back together. To adjust there is a little oval hole with a bung in the back plate that allows you to use a flat screwdriver to click the adjustment wheel, do this until you hear the shoes dragging and then back it off 2 clicks so it runs free.
Time to create page: 0.388 seconds
