What's the biggest battery you can fit in a Gen.4?
- Roger Fairclough
Topic Author
- Thank you received: 224
25 Dec 2022 17:42 #246543
by Roger Fairclough
Replied by Roger Fairclough on topic What's the biggest battery you can fit in a Gen.4?
Being doing some more research. Original battery has 370 CCA. Best so far found that is the same size has 450 CCA. That's an increase of 21.6%. Reality says that this should be enough unless I want to modify the mounting but this morning my neighbour has pointed me towards a battery maker/supplier less than 1 km away so I will investigate.
Now, whilst I am on, all things point to my original battery being a bog standard lead /acid variety ie not AGM. Anybody care to comment?
Merry Christmas.
Roger
Merry Christmas.
Roger
25 Dec 2022 19:02 - 25 Dec 2022 19:36 #246548
by Scimike
Replied by Scimike on topic What's the biggest battery you can fit in a Gen.4?
AGM is just designed for vehicles with Stop /Start technology. They can have a higher charge rate than standard flooded, but they are still lead based technology. This higher charge rate is ideal if your vehicle is stop/start. Hence they may draw slightly more current from a dumb alternator, but it won't cause any damage to the alternator or cabling, it's just charging faster.
If you have a smart alternator I suspect it now needs to know AH / CCA and AGM tech to allow the ECU to charge it.
SO dumb old fashioned alternator = no problem.
Modern smart alternator = ok if the ECU knows
Modern smart alternator and the ECU don't know = it may not charge it fully etc
I believe (could be wrong),that the G4 is not start /stop, so no need to go AGM?
Sorry don't know beyond the old tech. Unfortunately the smart stuff has a programmed code interfering with good old fashioned Volts/ohms/amps and how much it interferes changes from vehicle to vehicle. Some smart system don't do much, others want to know how old the battery is and the colour of your underwear etc.
Last edit: 25 Dec 2022 19:36 by Scimike.
25 Dec 2022 23:44 #246550
by lightning
Replied by lightning on topic What's the biggest battery you can fit in a Gen.4?
Sorry have l missed something here, why would you need a larger capacity battery. Has your existing battery gone flat with the use you are putting the vehicle to?
We've had no issues with the battery in ours, it's always kept up and no sign of it struggling.
26 Dec 2022 08:01 - 26 Dec 2022 08:12 #246552
Replied by yakuza on topic What's the biggest battery you can fit in a Gen.4?
This is a gen3 but might be similar.
I got a fridge for camping, extra lights, compressor, some sort of periodical electric leak, and do very much short trips 1 to 2km. My asian cheap 45Ah was not coping. Two years ago I changed to a 70Ah AGM. Original generator. Not had any issues at all since. Leave headlights or worklight on for 15 or 20 minutes, use the compressor without starting the engine, cooler fridge on overnight. The car sits in the garage in the cold winter for a week without charging, No worries. If the generator quits it will be replaced by one with higher amps of course but no apparent need now.
www.bigjimny.com/index.php/forum/8-my-ji...kuza?start=96#217746
Last edit: 26 Dec 2022 08:12 by yakuza.
26 Dec 2022 14:29 #246555
by Busta
Replied by Busta on topic What's the biggest battery you can fit in a Gen.4?
Also worth noting that CCA (cold cranking amps) isn't a measure of battery capacity. It's the maximum current the battery can output for 30 seconds at -18 degrees. The standard battery has more than enough CCA to start the car in those conditions, so there is no benefit to fitting a higher CCA (unless you have fitted an accessory that draws more current than the starter motor.)
If you want a higher capacity battery you need to look at AH (amp hours). You can fit a higher AH without needing to change anything else.
- Roger Fairclough
Topic Author
26 Dec 2022 20:14 #246563
by Roger Fairclough
As to why, read further back.
You can fit the Yuasa battery, ref. HSB 053 without changing anything as it is a direct replacement, so your final comment is answered.
Merry Christmas
Roger
CCA has taken over from A/H in the value that people put on the power of a battery, which is why I have quoted CCA and not A/H but if you want the comparison then the original battery has 370 CCA and 45 A/H whilst a direct replacement (physical that is) from Yuasa gives 450CCA and 50A/H.Also worth noting that CCA (cold cranking amps) isn't a measure of battery capacity. It's the maximum current the battery can output for 30 seconds at -18 degrees. The standard battery has more than enough CCA to start the car in those conditions, so there is no benefit to fitting a higher CCA (unless you have fitted an accessory that draws more current than the starter motor.)
Merry Christmas
Roger
Time to create page: 0.416 seconds
