Probably don't try this at home.
- Thank you received: 1869
11 Oct 2021 07:08 #239290
I accept absolutely no responsibility for any negative outcomes arising from trying anything like this. But it does make the point that a Jimny will Tow. Virtually. Anything.
Probably don't try this at home. was created by Lambert
11 Oct 2021 07:28 #239291
by Busta
Replied by Busta on topic Probably don't try this at home.
But they won't shift a nearly empty calf creep feeder on a wet, slippery marsh!
11 Oct 2021 09:18 #239295
Replied by Lambert on topic Probably don't try this at home.
More. Aggressive. Tyres.
- Roger Fairclough
- Thank you received: 211
11 Oct 2021 13:54 #239301
by Roger Fairclough
Replied by Roger Fairclough on topic Probably don't try this at home.
The power to weight ratio of the ant dragging the wasp is more impressive.
Roger.
Roger.
11 Oct 2021 20:36 #239327
by Scimike
Replied by Scimike on topic Probably don't try this at home.
Yep , that looks about the same max speed as when I tow my caravan. Just shows it will tow anything slowly
Just needs a few more ants under the bonnet.
14 Oct 2021 11:31 - 14 Oct 2021 11:35 #239403
by Busta
Weight is the Jimny's big handicap when towing, which is easily forgivable given all the advantages that come of having a lighter vehicle.
A Defender on exactly the same tyres (BFG KM2s) moves it no problem, simply because it's heavier.More. Aggressive. Tyres.
Last edit: 14 Oct 2021 11:35 by Busta.
Time to create page: 2.601 seconds
