Starter motor wiring
  • Samthejimnyfan
24 Sep 2021 13:32 #238930 by Samthejimnyfan
Starter motor wiring was created by Samthejimnyfan
After some help please. Has anyone a photo of the wiring going to the solenoid on the starter motor? We're rebuilding the engine install having put the M16a engine in and we didn't take enough photos. When we go to connect the earth lead to the battery having connected the live, we get sparks. No fuses blow. But i'm concerned we have something not right in the wiring. And I suspect it's the starter wiring.
We have the large feed coming in from the battery to the solenoid. Near to that connection are three or four smaller black wires with brass/copper ring connectors on the end. To all intents and purposes they look like they fit to the same post on the solenoid as the battery feed so we fitted them to the pole. I cant see anywhere else that they could fit but I wanted to check.
On another note I cant find anywhere workshop manuals or wiring diagrams for a jimny (2006 MY). Has anyone any links etc.
Thank you.
24 Sep 2021 23:50 #238934 by fordem
Replied by fordem on topic Starter motor wiring
They don't - the only thing that goes on the starter solenoid lug is the battery feed.
  • Samthejimnyfan
25 Sep 2021 10:56 #238935 by Samthejimnyfan
Replied by Samthejimnyfan on topic Starter motor wiring
Thanks.
In which case, can anyone assist me where these wires go?
They are in the same part of the loom as the battery feed and the starter solenoid wire from the ignition.
Really stuck at the moment so any help will be gratefully received.
Thank you
25 Sep 2021 14:52 - 25 Sep 2021 14:53 #238937 by Riccy
Replied by Riccy on topic Starter motor wiring
They are both negative wires. i can even see the shiny bolt hole where they go onto the engine block in your picture, just above the clutch cable, or they might go on one of the bolts that holds the starter in place. Either would work.
Last edit: 25 Sep 2021 14:53 by Riccy.
  • Samthejimnyfan
25 Sep 2021 21:28 #238948 by Samthejimnyfan
Thank you. Connected to the block and now working fine.
M16a makes such a difference. Still a few things to sort like a cranky starter solenoid. But already very pleased with the conversion.
  • Bigredjimny
03 Oct 2022 15:48 #245293 by Bigredjimny
Replied by Bigredjimny on topic Starter motor wiring
I know it’s a silly question, but we’re exactly did you put the small earths mate?
I’m having the exact same issue with my m16a swap now, cheers :)
Time to create page: 0.143 seconds
