Re:breathers
07 Mar 2021 21:37 #233524 by Mike G
breathers was created by Mike G
Quick one on breathers,
My understanding is that most people fit a seperate hose to each component, diff x2, tx box, gx box, which means you have 4 lines going up to the engine bay.  I was thinking about putting using one hose, starting at the rear diff, then when it gets to the tx box, using a 3 way connector, plugging in the tx box and then continuing the line up to the gx box and doing the same thing for that and the front diff. That would mean that only one hose went up to the engine bay.   Has anyone else done it this way?  If not, is there any particular reason you didn't go down this route?
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
07 Mar 2021 21:43 #233525 by Soeley
Replied by Soeley on topic breathers
I would have thought the less joints the better along the lines, just in case one comes loose?
07 Mar 2021 21:47 #233526 by Mike G
Replied by Mike G on topic breathers
True, I've never used those air line fittings before, not sure how robust they are. I don't suppose the hose takes up much space when it's all tie-wrapped together anyway.
  • justintime441
08 Mar 2021 02:55 #233530 by justintime441
Replied by justintime441 on topic breathers
I'm not sure if that's the best idea, while it does work, if enough water does enter into the single line, all your components would be screwed. This is hypothetical and will probably only introduce water into one component but it's something to think about. Separate hoses for each component would be best. Feel free to correct me if I'm chatting rubbish :DD
08 Mar 2021 05:34 - 08 Mar 2021 05:36 #233535 by HUN
Replied by HUN on topic breathers
As others already pointed out it's a good idea to have a continuous line without any joints. You could build either with or without joints that's just a secondary question. The most important in my opinion to use proper kit like one here:
X8GGY" post=233370
Or if you want a kit, I have them in my store
Dave
Don't use rubbish like garden hoses and clamps, stick with the proper stuff!
HUN
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Last edit: 08 Mar 2021 05:36 by HUN.
08 Mar 2021 05:46 - 08 Mar 2021 05:48 #233537 by X8GGY
Replied by X8GGY on topic breathers
Thanks Hun ;)
Link -  www.zookbob.com/breather-kits.html
I actually offer both types mentioned above, but prefer to hav all lines going back to a manifold block -
Last edit: 08 Mar 2021 05:48 by X8GGY.
Time to create page: 0.514 seconds
