Towbar
31 Jul 2020 12:37 #225894 by Wailin
Towbar was created by Wailin
Looking to fit a towbar to my 2002 jimny, it has a 2" body lift but I'm thinking that makes no difference? Could you recommend a towbar folks I'm struggling to find one online that will fit.
31 Jul 2020 16:26 #225898 by Scimike
Replied by Scimike on topic Towbar
I can confirm the body lift will make on difference, the towbars I have seen bolt to the chassis.
Surprised you can find any online, national shortages?
i suspect with a body lift you will not obscure the numberplate, so any fixed hitch offering will do.
www.just-tow.co.uk/product/suzuki-jimny-...ent-towtrust-towbar/
No direct experience of these, may not be cheapest, simply first Google result.
Mike
31 Jul 2020 17:10 #225899 by Lambert
Replied by Lambert on topic Towbar
If you want a good one try towtrust, it's better to go directly to them as they offer good deals.
01 Aug 2020 22:54 - 01 Aug 2020 22:55 #225960 by gilburton
Replied by gilburton on topic Towbar
Depends what you are towing but the towball will now sit 2 inches higher making the trailer slope.
I believe there is a standard EU height which all towbars are made to conform to.
Possibly you'll need to fit a drop plate (or a spacer on the drawbar) which also means getting one with a bolt on towball but these are more versatile anyway for bike racks etc.
I started off high and worked my way down ever since :-)
Last edit: 01 Aug 2020 22:55 by gilburton.
02 Aug 2020 05:37 #225964 by Lambert
The op said they had a body lift so the tow bar will be unaffected as its mounted to the chassis. The only increase in height is therefore going to be the increase in tyre radius over the standard tyre assuming taller tyres has been fitted.
02 Aug 2020 08:55 #225969 by Roger Fairclough
Replied by Roger Fairclough on topic Towbar
Tow bracket manufacturers have to stick to relevant standards so they will assume that the vehicle is standard and make the bracket to comply. If that means the ball would obstruct the number plate then a removable "swan neck" style is the usual option. If you then have a spare wheel fitted to the rear door further complications arise and the "swan neck" will be longer to put the ball outside of the tyre. Either way the fact that you have put body spacers on the vehicle is irrelevant. The bracket and ball are made to suit a standard car.
Roger
Time to create page: 0.237 seconds
