Newbie stumped (dashboard fuse location)
  • Clutha
03 Mar 2020 14:33 #219326 by Clutha
So, new (56 plate) arrival horn no worky, 1st diy job.
Got an owners manual, fuse box cover not where it says it is.
Give us a starter for 10, puleese.
03 Mar 2020 15:25 #219327 by Lambert
Check the wires to the horn they can snap. The fuse box is above the bonnet pull in the driver's footwell.
The following user(s) said Thank You: Clutha
  • Clutha
03 Mar 2020 15:49 #219329 by Clutha
Replied by Clutha on topic Newbie stumped (dashboard fuse location)
I had the horn connectors off, looked ok, thought a fuse check would be next easy option.
Two days driving around since taxed, loving it!
Thanks again.
  • gusthegorilla
03 Mar 2020 17:01 #219332 by gusthegorilla
Replied by gusthegorilla on topic Newbie stumped (dashboard fuse location)
The Jimny horn is an abysmal piece of rubbish, designed to satisfy the law, and nothing more..!!!!
Buy a Stabilo Nautilus, wire it via a relay...then spend your days scaring the hell out of old folks...!!!!
03 Mar 2020 20:16 #219340 by Soeley
The following user(s) said Thank You: Scimike
03 Mar 2020 21:09 - 03 Mar 2020 21:11 #219341 by Max Headroom
+2 For the Stebel Nautilus.
I chose the Compact version which, by making a carefully angled bracket out of a gash bit of stainless I had kicking around, have fitted it in same (almost) place as the original horn
Last edit: 03 Mar 2020 21:11 by Max Headroom.
Time to create page: 0.200 seconds
