Re:Heated screen?
- Thank you received: 1865
11 Dec 2019 12:17 #216388
Heated screen? was created by Lambert
Whatcha. Does anyone know if there was ever a Jimny gen3 that had a heated front windscreen? Has anyone had one offered as a replacement for a cracked screen and reverse engineered the wires?
Thanks in advance.
Thanks in advance.
- CC Baxter
11 Dec 2019 15:29 #216400
by CC Baxter
Replied by CC Baxter on topic Heated screen?
Hi Lambert, I had one of these for a VW Golf a couple of years ago. Screen people fitted it and I wired it (basic stuff - fuse relay switch, done). Apparently they're copies of the Ford quickclear screen and when the patent lapsed an after market company started making them. I never really got on with it as I found the strange pattern in the glass (a sort of honeycomb) disconcerting after dark.
Chris
Chris
11 Dec 2019 21:25 - 11 Dec 2019 21:27 #216414
by Scimike
Replied by Scimike on topic Heated screen?
Its is possible to do, the main issue is finding a supplier of a heated screen for the Jimny. As Chris said you can see the heating element wires in the screen if you look for them, but for me I did not mind the pattern in the glass.
I have them fitted in my 1960 series 2 Land Rover at the moment, the club did a group purchase from a Spanish manufacture of about 50 units at approx £120 a set, so you can get heated screens for anything if you can get enough people interested.
I made own wiring loom using the screen timer relay from a scrap Ford, works well and a must have in water logged Land Rover.
Not sure the Jimny ever have this as an option, it's an 80's design with little modernisation, not sure it's even an available on the GEN4.
May your windows stay clear.
Mike
Mike
Last edit: 11 Dec 2019 21:27 by Scimike.
12 Dec 2019 05:14 #216415
Replied by Lambert on topic Heated screen?
I think it's a combination of use and deterioration that is causing me to want one. I suspect that my heater matrix is not running as efficiently as possible but I don't want to get involved with replacement unless I have no choice. Compounding that is being in and out of the car all the time in all weathers and consequently transferring quite a lot of moisture into the car on wellies and clothing etc which has left me with a few occasions of having to scrape ice off both sides of the windshield which is just as much fun as it sounds. I suppose the other alternative would be a few kilos of that silica drying stuff?
12 Dec 2019 07:53 #216416
Replied by Daniel30 on topic Heated screen?
Sometimes you don't see the grime/dirt on the inside but a good clean helps to clear it quicker
12 Dec 2019 17:32 #216432
Replied by Riccy on topic Heated screen?
Use the aircon to clear it, works a treat. Also as Daniel says, clean glass clears faster
Time to create page: 2.087 seconds
