Steering
- Mole
22 Oct 2019 07:30 #215029
by Mole
Steering was created by Mole
Up till now I thought I had just kept knocking my tracking out but turns out if I turn the wheel to full lock so the wheel stops then carry on turning a bit harder (not massively hard) I can move the steering wheel. Now I have only found this out when I get to work this morning so will check the splines are all tight and the ujs in a bit but is there any thing else it could be just of the tops of your heads??
My steering box dose have play in it and has been tighten but dose need replacing I have a spare just not put it in yet
- Thank you received: 2004
22 Oct 2019 08:07 #215033
Sounds suspiciously like a worn steering column joint, does it do it equally both ways?
- Mole
22 Oct 2019 08:25 #215038
by Mole
Replied by Mole on topic Steering
Not sure yet will have a look at lunch time. The joint your referring to it that the one with the rubber cushion? Also what is under the rubber boot along the shaft?
22 Oct 2019 08:36 #215041
If it what I think you mean it's to minimize nvh up the column. Is the additional movement to a hard or soft stop?
- Mole
22 Oct 2019 12:27 #215045
by Mole
All sorted now thank you just needed to tighten the bolt the box end. Think the next job will be changing the box for the new one. Thanks for the help
Time to create page: 0.092 seconds
