vvt no 4L
  • ozzyboy
14 Oct 2019 17:53 #214760 by ozzyboy
vvt no 4L was created by ozzyboy
hi
just tried to put a 2008 vvt into 4L using the correct sequence
the light comes on flashing
buzzer sounds
then the light goes out
is there a problem
thanks in advance
15 Oct 2019 04:15 #214765 by Lambert
Replied by Lambert on topic vvt no 4L
That's probably going to be electrical. There's a complete fault finding procedure in the Jimny information wiki at the top of the page.
The following user(s) said Thank You: ozzyboy
  • GF68
15 Oct 2019 06:42 #214770 by GF68
Replied by GF68 on topic vvt no 4L
Was your foot on the clutch, my 2005 won't do it unless it is.
  • CC Baxter
15 Oct 2019 08:28 #214778 by CC Baxter
Replied by CC Baxter on topic vvt no 4L
Yeah, all that. Got an '08 at home that sometimes needs encouragement (neutral, clutch in and perhaps some rocking on the gears). One tip I've yet to try - park the car on level ground (handbrake on, all best practices observed) apply your angry face and dance around the car three times in an anticlockwise direction. I think this one is to embarrass the car into submission.
Chris
  • GF68
15 Oct 2019 11:05 #214788 by GF68
So on mine recently I had electrical issues (could not get 4WD at all) and it turned out to be a broken wire on the front switch on the transfer box. But in fault finding I ended up taking both the 4WD switch and the 4WD-L switch out to investigate.
When you press the button on the dash do you hear movement in the transfer box?
Might be worth a look underneath at the back switch to see if the wires to it are good and they are still plugged in.
As I understand it, once you are in 4WD and press the button for 4WD-L then the switch on tx box has to sense the movement within 2 seconds or it fails to engage.
  • ozzyboy
15 Oct 2019 12:22 #214791 by ozzyboy
Replied by ozzyboy on topic vvt no 4L
yes
tried with foot on and off the clutch
