Tyres
- Roseblade
29 May 2019 13:17 #209183
by Roseblade
Tyres was created by Roseblade
Hi all, I am new to this so please excuse any unintended gaffs.
I have a 2008 jimny with 205/70/15 road tyres fitted. I am needing to use the car for my work in the woods and want to put higher profile all terrain tyres on (less damage to rims when I slip by a tree stump). I have no suspension lift or other mods.
My question is can I fit full profile 195/15s on standard 5 1/2 J steel rims without any Mods?
Many Thanks In advance for any advise.
- Thank you received: 2004
29 May 2019 13:54 #209184
Welcom to the forum.
Yes you can. Have a look in the technical area and there's a sticky on what will fit. Also available in the wiki section in the top banner.
The following user(s) said Thank You: Roseblade
- Roseblade
29 May 2019 22:39 #209204
by Roseblade
Replied by Roseblade on topic Tyres
Many thanks for the heads up. I will check it out. I see from the placard that the recomended size is 195/80/15 which by my dogdy maths would have side wall of 156mm which would be an improvement on my 205/70/15s at 143.5mm side wall.
My old samurai had 195/15s ie full 195mm side walls. I am hoping to use the same tyres on the jimny without having to modify it.
30 May 2019 04:11 #209208
Ah . The picture GeorgeC posted is actually of a 2019 gen4 model, the 195 is not a manufacturer recommended tyre on the gen3. It is a modification that fits without further alteration but should be mentioned to the insurance as a modification.
30 May 2019 07:23 - 30 May 2019 07:28 #209219
Also typically if a tyre doesn't have an aspect ratio printed on the side it will usually be an 82 not a 100. 85 and 100 are normally marked as such.
Edit. Unless you're looking at tyres with the imperial nomenclature like a 7.50 r16 they are 7.5 inches tall and wide.
Last edit: 30 May 2019 07:28 by Lambert. Reason: Additional information.
