GV engine
18 Jul 2018 22:03 #194433 by Johnniehec
GV engine was created by Johnniehec
Hi which engine will be in a 2005 Grand vitara 3 dr 1.6 16v? Any good for a Jimny upgrade, how much work? Any other bits any good for Jimny upgrade?
Cheers John.
19 Jul 2018 06:15 #194443 by Riccy
Replied by Riccy on topic Re:GV engine
It will be the m series, but it’s 50/50 if it’s vvt or not at that year. Would be good for a jimny tho, just got to match vvt to vvt when swapping engines.
The vvt ones have a bulge at the front of the engine which is the usual giveaway.
Brake calipers/hangars fit as well I believe, but you need the vented discs for a diesel jimny to go with them.
29 Aug 2018 16:31 #195537 by Johnniehec
Replied by Johnniehec on topic Re:GV engine
How about a 2001 gv1600? Would it be G16? Looking to put it in a 2002 soft top with G13bb cheers
John.
29 Aug 2018 17:44 #195540 by Riccy
Wouldnt know without having a look. Would suggest that the G series engines have a timing belt on the front of the engine and on the timing belt cover is embossed '16 valve'.
M series engines have a plastic cover on the top over the spark plugs and coil packs, and a timing chain instead.
The G series is much more complex to convert i believe, but having not done it i wouldnt know im afraid.
Time to create page: 0.086 seconds
