4wd problem
  • Greenwood
20 Jun 2018 17:51 #193678 by Greenwood
4wd problem was created by Greenwood
Hi all when I put my jimny in to 4x4 the gear stick is jumping around and the light is flashing what could be the problem with it thanks Mick
  • Greenwood
29 Jun 2018 16:57 #193862 by Greenwood
Replied by Greenwood on topic 4wd problem
Any help any 1
29 Jun 2018 17:15 #193863 by Riccy
Replied by Riccy on topic 4wd problem
could be a multitude of things there.
Obvious place to start is the transfer box and front prop (if its only when in 4x4 then the front prop is probably the culprit).
Im guessing that the front prop has blown a UJ, probably at the t-box end. Take it off to check, not obvious when on the car sometimes. UJ should move freely and not be loose or notchy. There's grease nipples which need grease when servicing, but is usually skipped.
29 Jun 2018 18:17 - 29 Jun 2018 18:36 #193867 by X8GGY
Replied by X8GGY on topic 4wd problem
Have you got a body-lift fitted?
I’ve seen the rubber boot pull the stick out of ‘gear’ before now...?
Edit : thinking about it some more - as a quick trial, take the rubber boots off and try it without...?
Last edit: 29 Jun 2018 18:36 by X8GGY.
Time to create page: 0.159 seconds
