Off-road tips
  • apayne
26 May 2018 20:51 - 26 May 2018 20:52 #192969 by apayne
Off-road tips was created by apayne
Hi all,
Hoping to get some tips to get the Jimny ready for a bit of off-roading without doing too much to it.
I took the Jimny down some tricky lanes today and due to the little floor clearance I ended up scraping the underside a fair few times. First off, can someone please advise what the parts are that I've highlighted/circled in my photo... Is this the suspension arm? Pretty sure the part circled blue is what was hitting the rocks/floor on steep declines as one of them had a dent on the very bottom. Are these easily replaced if damaged? Looks like it's welded to the chassis.
So got me thinking... what's the easiest way to get some height on the Jimny? Thinking a 2" lift and some mud tyres. How difficult is the 2" lift kit to fit and are there any other suggestions?
Cheers
Last edit: 26 May 2018 20:52 by apayne.
27 May 2018 08:00 #192974 by Riccy
Replied by Riccy on topic Off-road tips
They are the 'Radius arms'. The part circled blue is the mount welded to chassis and not a spare part as such. Guards are available for the mounts.
2" suspension lift would make the radius arms sit lower and be much less likely to catch these parts. Easy to fit, just swap springs & shocks. May need extended brake lines. Like everything, you get what you pay for, so dont expect a super cheap lift kit to be all that great ;-)
Try just the tyres first, these make more difference than anything else. 215/75r15 is as big as you can sensibly go before the gearing needs altered.
  • apayne
27 May 2018 12:58 #192977 by apayne
Replied by apayne on topic Off-road tips
Thanks Riccy. Gonna get some guards for the mounts!
I'll also look at getting the 2 inch lift as well as the 215/75r15 tyres!
  • wombat
27 May 2018 15:07 #192978 by wombat
Replied by wombat on topic Off-road tips
Hi, just be aware that a suspension lift will not give you increased ground clearance, it will give you more clearance to fit bigger tyres which will increase ground clearance
  • apayne
27 May 2018 15:53 #192979 by apayne
Yep thanks. Do you think the 215/75/15 tyres would fit without the 2 inch lift?
27 May 2018 16:31 #192981 by Riccy
apayne wrote: Yep thanks. Do you think the 215/75/15 tyres would fit without the 2 inch lift?
That size will fit no problem without the lift (unless using offset wheels or wheel spacers, some have slight issues with remould tyres, which are slightly bigger than stated).
235/75r15 is the next logical step from that, but as said it will mean gearing needs to be altered (especially if off-roading).
Time to create page: 0.189 seconds
