jimny wont start
- milkymoo
17 Mar 2018 11:48 #190534
by milkymoo
jimny wont start was created by milkymoo
hi there i have a 00 jimny and swapped the engine out of the donor jeep which has the same engine and was running perfect. i now have to engine in but it will turn over but getting no spark. getting loads of fuel. the check engine light does not come on at all. any ideas both jeeps where working before stripping just the engine i replaced dropped a valve
17 Mar 2018 19:14 #190542
by facade
Replied by facade on topic jimny wont start
Probably one of them has both a crank and a cam sensor, and the other has just a cam sensor.
The ones with just a cam sensor have a different number of sensor teeth on the cam to the ones with both, there have been a couple of threads about it, either adding a crank sensor when there wasn't one, or changing the sensor teeth on the cam, depending upon which type of engine the car expects.
- milkymoo
18 Mar 2018 02:22 #190550
by milkymoo
Replied by milkymoo on topic jimny wont start
so both have only a cam sensor. have checked the ecu key and imobiliser. all working good (thought might have blown somethiing) all live and eath wires are working going to the ecu and the cam sensor and the coil packs but cant get a spark i am really baffeled
18 Mar 2018 09:18 #190558
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic jimny wont start
Might be worth swapping the cam sensor over with the one from the engine you removed, Just to rule it out.
- milkymoo
18 Mar 2018 12:54 #190567
by milkymoo
Changed the cam sensor. No cel light on the dash. The diagnostics computer won't connect to anything in the system
- milkymoo
19 Mar 2018 16:49 #190605
by milkymoo
i have solved the problem it was the map sensor on the carb was faulty and upset the whole system
Time to create page: 0.265 seconds
