None Charging Jimny
- Grasshopper
Topic Author
- Senior Member
- Thank you received: 5
Looking for some ideas on a none charging issue on a M13A engine.
In ignition position two the battery charge light is on, once the engine is running the light goes out and remains so.. .However the vehicle if left to normal on road running it will eventually flatten the battery. Using a multimeter a fully charged battery voltage is indicated, however this does not increase/change when RPM is increased ( I would be typically looking for 14.1 plus volts ).
I have fitted a new alternator and since the battery was eight years old I have also fitted a new battery, still no charging the battery remains at basic voltage I have obviously looked for bad connections etc but nothing visible.
Any ideas would be much appreciated
Dave
The only benefit of age is experience.
Just a quick one - a thought that is coming from personal and humiliating experience -. Is the alternator belt tight enough.Grasshopper wrote: Hi All
Dave
- Thank you received: 1982
It's been fettled just a tad.
- Grasshopper
Topic Author
- Senior Member
The one that has got me going a bit is Jazz's suggestion of "checking the fuse". I assume you mean the 80 amp fuse hidden away under the engine bay fuse box.which looks a less than easy to get at. Surely if that's blown there will be no electrical power throughout the vehicle.
That said I read on another forum somebody referred to the fact that if it had failed the alternator won't charge the battery but he does not say the whole system is dead. Suppose I will have to have a dig under that can of wiring/worms.
