Replacing front shock
- 2013gary
30 Jan 2018 11:51 #188975
by 2013gary
Replacing front shock was created by 2013gary
Hi all,
I had a bit of an impromptu excursion off road on the way to work this morning, and ended up hitting two very large rocks on the side of the road. The nearside front shock absorber needs replacing other things. Is this fairly easy to change? I've changed brakes and track rod ends before but have never done a shock absorber. I've read on here that it can be done without even removing the wheel, or is that just for the rear?
Many thanks,
Gary
Many thanks,
Gary
- Thank you received: 1859
30 Jan 2018 11:58 #188976
Replied by Lambert on topic Replacing front shock
It is possible with the wheel on but it is so much easier with it off. It's literally just 2 fairly tight bolts and you're done . If it takes you half an hour you have stopped for a cuppa half way through.
- 2013gary
30 Jan 2018 13:35 #188977
by 2013gary
Replied by 2013gary on topic Replacing front shock
Thanks for the reply. I'll soak them both in WD40 just to be on the safe side.
- CharlesS
30 Jan 2018 22:39 #189004
by CharlesS
Replied by CharlesS on topic Replacing front shock
PB Blaster is much better when it comes to freeing rusted bolts.
- 2013gary
31 Jan 2018 09:57 #189009
by 2013gary
Thanks for the tip; I've never heard of that. I've used Plusgas before but didn't find it much better than WD40.
- Thank you received: 674
31 Jan 2018 16:44 #189018
Replied by jackonlyjack on topic Replacing front shock
It's easier to cut top nut off with grinder
