it fell off !!
29 Oct 2017 06:28 #185606
by paul2u
it fell off !! was created by paul2u
i went out to nip to the shop and the engine started up and let out a scream from the fan belt where upon the charging light came on i looked under the bonnet in the dark and could see it had thrown the belt , next morning i went to get two new belts and fit them got the alternator belt on and went to tighten it up when the crankshaft pulley fell off as they do , new one ordered arriving on Tuesday, an easy job to do but a little costly at £121 for a genuine part many years ago we could make pulley,s out of one block of steel why the hell do we need to stick them together with crappy glue,theses days ? lack of good engineers i guess on the bright side it all happened in my back yard and not on the road
- Thank you received: 1879
29 Oct 2017 07:09 #185608
Replied by Lambert on topic it fell off !!
At least you got the pulley nut off, they can be difficult.
29 Oct 2017 07:47 #185609
by paul2u
Replied by paul2u on topic it fell off !!
aye that was easy to do just locked the engine and it came off no bother with a Tommy bar it looked like it had some sort of glue on the bottom of the thread , might need to put something back when i reassemble like lock tight
29 Oct 2017 08:10 - 29 Oct 2017 09:07 #185610
by Foxtrot
Replied by Foxtrot on topic it fell off !!
One of my Jimnys got recalled back for a faulty pulley. Here is the information
www.vehicle-recall.co.uk/recall/R/2010/067
Last edit: 29 Oct 2017 09:07 by Foxtrot.
29 Oct 2017 10:08 #185612
by Busta
Years ago nobody would touch an engine with over 60,000 miles on it because it would be worn up. Nowadays small engines make twice the power of old and are capable of 3 times the mileage using half the fuel and you never have to do so much as take the rocker cover off. If it takes a fancy crank pulley to achieve this then I'm not complaining! I don't think the engineers are doing such a bad job.
Replied by Busta on topic it fell off !!
paul2u wrote: many years ago we could make pulley,s out of one block of steel why the hell do we need to stick them together with crappy glue,theses days ? lack of good engineers i guess
29 Oct 2017 11:24 - 29 Oct 2017 11:50 #185615
by paul2u
but the fancy crank pulley did not achieve this it failed because of the glue ! so at this rate you may need lots of crank pulleys to get to big millage having that said my last jimny had 185 ,000 on the clock and never had that problem this is a first for me such an important part on an engine should be constructed a little better than being stuck together with bostik
i totally agree engines have come a long way forward in time with a lot less break downs its the success of progression if there is a weak link in the chain then its better dealt with and make the product better a better made pulley would help to move suzuki forward a bit more and add to its already good name
Last edit: 29 Oct 2017 11:50 by paul2u.
Time to create page: 2.613 seconds
