None power steering box?
- Thank you received: 1876
21 Aug 2017 18:05 #183527
None power steering box? was created by Lambert
Is or was there a Jimny in the UK that wasn't power steering and if so is its box compatible with a pas car? Allegedly in certain markets it is just a pas box with the pressure lines blanked off?
22 Aug 2017 08:34 - 22 Aug 2017 08:35 #183536
Replied by yakuza on topic None power steering box?
The steering box for the Suzuki SJ-series has exactly the same footprint and sizes. But it has no power.
So Suzuki should not need to put a power version in a car and blank it when they already have the non-power version in their production. (Was still made in India/paki/bangla until a couple of years ago)
Last edit: 22 Aug 2017 08:35 by yakuza. Reason: typo
22 Aug 2017 10:48 #183541
Replied by Lambert on topic None power steering box?
So an sj box would fit. Do you know how many turns one is lock to lock? Ie is it a different ratios to the pas box?
24 Aug 2017 17:04 - 24 Aug 2017 17:04 #183633
I think its the same more or less. Pitman arm might have to be changed as the SJ one has more drop. depending weather you have a lift or not i guess. not sure if these boxes spline output shaft has other dimensions on vitara, jimny and SJ. aftermarket pitman arms excists.
Last edit: 24 Aug 2017 17:04 by yakuza.
