Remove dash
- hunter1084
15 Sep 2016 05:35 #172331
by hunter1084
Remove dash was created by hunter1084
Is there a how to guide on removing the dash in a facelift Jimny? Had a look but can only find a guide on removing the stereo. Only need to remove it to access the hole in the corner of the firewall.
- kevinbarry18
15 Sep 2016 18:46 #172362
by kevinbarry18
Replied by kevinbarry18 on topic Remove dash
What are you planning to run through fire wall ?
- hunter1084
15 Sep 2016 18:49 #172363
by hunter1084
Wires for the switch on the light bar, so don't need to pull the dash completely out I hope. Just need to access that rubber grommet
Replied by hunter1084 on topic Remove dash
kevinbarry18 wrote: What are you planning to run through fire wall ?
- Thank you received: 1885
15 Sep 2016 19:20 #172366
Replied by Lambert on topic Remove dash
I found that it is possible to get at that bung if you sort of sit upside down in the seat. And for those who have met me yes it is ruddy painful for a bear my size to be upside down in a car as small as a Jimny.
15 Sep 2016 19:27 #172367
by Keithy
Replied by Keithy on topic Remove dash
I cheated.....I taped the wires to a welding rod and stood up outside the car and did it11/60 wrote: I found that it is possible to get at that bung if you sort of sit upside down in the seat. And for those who have met me yes it is ruddy painful for a bear my size to be upside down in a car as small as a Jimny.
- hunter1084
15 Sep 2016 19:58 #172369
by hunter1084
I'll give it a go with the wire will be alot easier if I don't have to take the dash apart!
Time to create page: 0.126 seconds
