Transfer box
- Barkis21
20 Jul 2016 18:33 #170291
by Barkis21
Transfer box was created by Barkis21
Can I fit a standard transfer box in a vvt or not
21 Jul 2016 02:33 #170303
by Busta
Replied by Busta on topic Transfer box
Yes, but the ratios are different so it will make your gearing very long unless you change the gearbox to.
- Barkis21
22 Jul 2016 14:20 #170361
by Barkis21
Replied by Barkis21 on topic Transfer box
What do you mean by the gearings different will it be worse off road
22 Jul 2016 23:20 #170383
by Busta
I said it makes the gearing longer but actually it makes it shorter. Assuming yours is a manual, the gearing in high range will be 30% lower but in low range it will only be 10% lower. Depending what size tyres you run, it will make the car very revvy on-road without giving much benefit in low range. Probably good for rally driving though!
- Barkis21
23 Jul 2016 04:38 #170384
by Barkis21
Ah right thanks
- Barkis21
23 Jul 2016 04:49 #170385
by Barkis21
Will the speedo need adjusting to suit
