Code reader ??
- dirtylanes
22 Feb 2016 12:23 #162796
by dirtylanes
Code reader ?? was created by dirtylanes
I have a 2006 VVT Jimny and am looking to buy a code reader, am I right in that the type I will need is OB2 ? and Is there a type or model
that I should be looking at, also is it worth buying something that some would say is a toy as opposed to a pro one. John
22 Feb 2016 12:41 #162798
by gilburton
Replied by gilburton on topic Code reader ??
Yes OBD 2. The simple cheap ones will give you the codes which will point you in the right direction and also allow you to reset the check light.
It all depends what you want to spend and the use you may get out of it.
I've not used my cheap one on the Jimny but my wifes Alto was playing up and it had no problem in directing me to the lambda sensor failure.
The ones that connect to laptops can also give you figures for the engine while running but obviously cost more.
- Laminak
23 Feb 2016 20:15 #162902
by Laminak
Replied by Laminak on topic Code reader ??
To read malfunction code, I use an ELM327 reader
The link explain how to make a diagnostic with OBD and why
outilsobdfacile
The second link is my tool
elm327-usb-obd2-metal
And I will purchase a bluethouth one
outilsobdfacile
23 Feb 2016 22:02 #162909
Replied by jackonlyjack on topic Code reader ??
No eBay APP ID and/or Cert ID defined in Kunena configurationas anyone used this and the torque app for android phones
Jack
Jack
- Reloaded
24 Feb 2016 08:59 #162921
by Reloaded
Replied by Reloaded on topic Code reader ??
I use similar and torque pro. Use the pay-for version of the app, it's awesome. Great for real time info etc...
24 Feb 2016 20:43 #162955
by Rhinoman
Replied by Rhinoman on topic Code reader ??
I did some testing on some ELM variants, the Bluetooth ones are really quite slow, a wired USB interface is the fastest but the Wi-Fi version isn't far behind.
Time to create page: 0.182 seconds
