Engine change
  • Charlie b
20 Apr 2014 15:20 #112748 by Charlie b
Engine change was created by Charlie b
Hi guy I've bought a t plate jimny witch has the sohc in it
The cam has scored the cam carriers ,,,
Is this an simple fix
Or do I need a new head!,,,
Also wot is needed to put the sohc engine in it are the boxes the same and how easy is the conversion
Hope you's can help :laugh:
  • Chazg83
20 Apr 2014 16:30 - 20 Apr 2014 16:34 #112757 by Chazg83
Replied by Chazg83 on topic Engine change
Alright Charlie welcome in, everyone this is my mate Charlie he's bin bitten buy the Jimny bug lol, be good to have you out in the winter will be good, guys any information to help him out will be grateful on the cam and carriers and head or a engine swap from single cam to a dohc, not to sure weather the looms ecu sensors are same?? Cheers
Last edit: 20 Apr 2014 16:34 by Chazg83.
  • Dave cc
20 Apr 2014 16:58 #112768 by Dave cc
Replied by Dave cc on topic Engine change
Welcome sounds like the head is scap its a common fault easiest fix find another head as for dohc cam engine sure it could be done but you would need engine gearbox and loom ecu etc would be a hell of a lot of work so just replacing the head would be the easy option
regards dave
20 Apr 2014 17:20 #112771 by Rhinoman
Replied by Rhinoman on topic Engine change
If you're going to be going with bigger tyres then a G16B conversion would be worth considering.
  • Chazg83
20 Apr 2014 17:29 #112772 by Chazg83
Rhinoman wrote: If you're going to be going with bigger tyres then a G16B conversion would be worth considering.
If you put the 1.6 in what else do you change? Ecu?? Do you keep the 1.6 inlet or put the 1.3 inlet on the 1.6 and run 1.3 ecu?? Cheers
20 Apr 2014 17:40 #112777 by Rhinoman
You use the 1.3 manifolds, do a forum search for 'G16B conversion' there are a few threads that describe how to do the conversion, its not quite a straight swap.
Time to create page: 2.577 seconds
