Lambda/O2 Sensor Harness location
X-Eng Simon wrote: If your box is electronically controlled, the TC Lockup is just controlled by a solenoid valve - which you could power with a push button! Just splice in to the TCC wire and connect to +12v via a switch or push button. Then, the gear controller will control it as normal, but when you power it via the switch, it will lock up for you on demand.
Si
I am thinking an - ON1 / OFF / ON2 - switch. So that ON1 is normal, OFF would act as an OFF when it was locked automatically or OFF when it was locked manually in ON2. ON2 would lock it manually. This way it avoids +12v going to the ECU in the wrong direction.
- X-Eng Simon
You could just use a two way switch such that the solenoid is connected to the ECU one way and to 12v the other. I can't see any situations where you would want it unlocked when the ECU thinks it ought to be.
Si
X-Eng Simon wrote: You could just use a two way switch such that the solenoid is connected to the ECU one way and to 12v the other. I can't see any situations where you would want it unlocked when the ECU thinks it ought to be.
Si
My wife's Nissan has an unlock switch so you can switch it on and off once its locked (if you see what I mean). I use it all the time to unlock when going uphill etc to bring the revs back up without having to kick it down.
- X-Eng Simon
That's a very good point - which I'd not thought of!
Si
X-Eng Simon wrote: I'm pretty sure feeding voltage back into it will be OK
Si
That would blow the output stage.
