Pcv valve
- Bendywagon
22 Jul 2013 09:42 #77822
by Bendywagon
Pcv valve was created by Bendywagon
Hi guys just wondering if any of you know how to check pcv.i had it off can blow air through it,but it does rattle if you shake it..
- markyp2000
22 Jul 2013 10:14 #77836
by markyp2000
Replied by markyp2000 on topic Pcv valve
Pcv?
- Bendywagon
22 Jul 2013 11:22 #77844
by Bendywagon
Replied by Bendywagon on topic Pcv valve
Pcv is a small valve that enters thr rocker cover on the left hand side of the engine.just goggled it and it says you can clean it with carb cleaner and if it rattles it working right.
- GuardianAngel
22 Jul 2013 11:29 #77845
by GuardianAngel
Replied by GuardianAngel on topic Pcv valve
Yes it has a little one way trap door that will flap if you shake it. I have cleaned mine out to stop the engine dipping on idle.
- Bendywagon
22 Jul 2013 12:00 #77849
by Bendywagon
That was the same problem I was having on idle,seems to be fine now.
- gus2000
22 Jul 2013 14:57 #77871
by gus2000
Replied by gus2000 on topic Pcv valve
Time to create page: 0.270 seconds
