linana 1.6 m16 eng in jinmy
- winter
29 Jan 2013 22:11 #60204
by winter
linana 1.6 m16 eng in jinmy was created by winter
im fitting a linana 1.6 m16 eng into my jimny iv read you use jimny parts which is ok but i have been told you can use the linana inlet dose any one eles know if this is right or hav used the linana inlet them selfs thanks
- gus2000
30 Jan 2013 01:16 #60218
by gus2000
Replied by gus2000 on topic linana 1.6 m16 eng in jinmy
Hello, I believe that here they respond to your questions
suzuki88.mforos.com/407023/9411638-instalacion-motor-1-6-16v/
(in spanish) See pictures
Gustavo
Gustavo
- Cider
30 Jan 2013 17:48 #60263
by Cider
Replied by Cider on topic linana 1.6 m16 eng in jinmy
Wow
A very good link, With great pictures. Thank you
What starter did they use ?
Cheers
Cheers
- Bigchridy
30 Jan 2013 18:12 #60278
by Bigchridy
Replied by Bigchridy on topic Re: linana 1.6 m16 eng in jinmy
IIRC both the m16a and m13a inlets are the same except the m13a from a jimny has extra vac lines for the auto hubs.
Also the jimny ecu will not power the m16a throttle body. Although I have not tested this myself.
Sent from my Nexus 7 using Tapatalk 2
- gus2000
30 Jan 2013 21:05 #60318
by gus2000
8. el motor de arranque del 1.3 mueve sin problemas el propulsor 1.6
8. the starter of the 1.3 moves without problems the engine 1.6
it uses the starter of the 1.3
Rmoure of the 1.3 engine uses the ecu and intake manifold witouth red injectors jimny (180cc/m). And install in it a green (220 cc/m) injectors of 1600 cc engine to compensate the displacement increase
Gustavo
Gustavo
- winter
30 Jan 2013 21:19 #60319
by winter
Replied by winter on topic linana 1.6 m16 eng in jinmy
well im still going to try the 1.6 intake lets see what happens i shell let you all know soon
