Jimny 2" pitman drop arm!
  • Leepeet69
27 Jan 2013 20:29 #59889 by Leepeet69
Jimny 2" pitman drop arm! was created by Leepeet69
Does anyone else make/sell a jimny 2" steering pitman drop arm? Jimnybits have non in stock and don't know when they will have stock?
Thanks
  • mudman
27 Jan 2013 21:16 #59899 by mudman
Replied by mudman on topic Jimny 2" pitman drop arm!
unless your running a massive lift you dont need one im running +3 and my steerings fine..... save your money mate
  • markyp2000
27 Jan 2013 21:27 #59901 by markyp2000
Replied by markyp2000 on topic Jimny 2" pitman drop arm!
Iv got a 4.5" suspension lift and iv not got one smoogy fitted one and i belive he had trouble with it hitting the panard rod id save your money
  • Smoggy
27 Jan 2013 22:38 #59921 by Smoggy
Replied by Smoggy on topic Jimny 2" pitman drop arm!
Here here, wost thing i ever fitted. Take Markys advice and dont get one you dont need it.
  • Leepeet69
28 Jan 2013 17:39 #60001 by Leepeet69
Replied by Leepeet69 on topic Jimny 2" pitman drop arm!
I've got a 3" suspension lift and 2" body lift running 31's and the steering wobbles and them tends to wonder across the road, had the wheels rebalanced and tracking checked all ok! I was told the steering arm joint that goes from the steering box to the steering arm was on its limit and wasn't centring causing my truck to wonder??
I haven't got a steering stabiliser fitted either???
  • markyp2000
28 Jan 2013 17:58 #60004 by markyp2000
Fit a stabiliser and check your king pin bearings by jacking the front up hold the wheel at 12 & 6 oclock and wobble it if there is play king pins may be shot then at 3&9 oclock if there is play it may be a track rod end also have you got caster correction bushes in the front or corection arms and check your tyre pressures and panard rod bushes
