wheel spacers
  • barnes
25 Dec 2012 20:14 #56191 by barnes
wheel spacers was created by barnes
hi all I been looking at wheel spacers for the Jimmy and I'm stumped. I don't know whether to get 30mm spacers or 55mm ones. what's the pros/cons and if anyone has pictures of either that would be great thanks
  • adamjimny
25 Dec 2012 20:17 #56192 by adamjimny
Replied by adamjimny on topic wheel spacers
the further the wheel is away from the hub the more leverage there is on the wheel bearing causing faster wear. 30mm will be enough im sure because its a big difference.......just over 1" on each side!
  • iloveics
25 Dec 2012 20:20 #56193 by iloveics
Replied by iloveics on topic wheel spacers
what he said,
also poor quality ones, people have had bad experiances with them breaking.
you considered offset wheels?
tyresdirectuk.co.uk/shop/product-info.ph...;-Daihatsu)&id=31179
these should give you about 20mm each side
  • adamjimny
25 Dec 2012 21:18 #56200 by adamjimny
agreed offset wheels are best but if using wheel spacers then get the bolt on ones that are cnc'd not the cast ones (they work ok but can cause problems) i use wheel spacers no problems
  • TomDK
25 Dec 2012 22:15 #56206 by TomDK
Replied by TomDK on topic wheel spacers
adamjimny wrote: agreed offset wheels are best but if using wheel spacers then get the bolt on ones that are cnc'd not the cast ones (they work ok but can cause problems) i use wheel spacers no problems
+1
Like these
www.jimnybits.co.uk/shop/wheel-spacers/s...pacers/prod_292.html :)
  • adamjimny
25 Dec 2012 22:22 #56207 by adamjimny
+1
Like these
very good set and cheap!!!
Time to create page: 0.413 seconds
