Fuel treatment?.
  • 247sniper
06 Jan 2012 17:44 #30160 by 247sniper
Fuel treatment?. was created by 247sniper
Do you guys use any form of fuel treatment/cleaner in your Jimny?
Steve.;)
  • ZookFastback
06 Jan 2012 17:48 #30161 by ZookFastback
Replied by ZookFastback on topic Re: Fuel treatment?.
Yep, I put a little bottle of Injector cleaner in once a month. I do about 4000k's/month and this seems to keep the injectors "Happy". Cheap at $2.99/bottle.
Also, once a year when I change the oil in diffs, gearbox and transfer case, I put a small amount of Nulon diff treatment in each case/diff.
06 Jan 2012 18:23 #30171 by dirtydogz
Replied by dirtydogz on topic Re: Fuel treatment?.
Yes the same here, l use red x injector cleaner every second fill up.:)
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
07 Jan 2012 12:48 - 07 Jan 2012 13:57 #30207 by facade
Replied by facade on topic Re: Fuel treatment?.
Shouldn't be necessary.
But if you believe it works, put it in.
(I suspect that "injector cleaner" is a very expensive way to buy paraffin, likely with a squirt of cellulose thinners added for good measure)
EDIT not thinners, nail varnish remover
"Octane booster" is toluene (cellulose thinner)
"Magic cleaner additive" is acetone (nail varnish remover)
"fuel system cleaner/water remover" is isopropyl alcohol (tape head cleaner)
Last edit: 07 Jan 2012 13:57 by facade. Reason: to correct info
07 Jan 2012 19:43 #30223 by Foxtrot
Replied by Foxtrot on topic Re: Fuel treatment?.
Yes, I use red x injector cleaner
  • adamjimny
08 Jan 2012 21:43 #30322 by adamjimny
Replied by adamjimny on topic Re: Fuel treatment?.
I use it before the MOT as emissions are usually high but this lowers it slightly.
But then mine isnt a daily driver so if its used regulary it wont be needed
Sent from my GT-I9100 using Tapatalk
Time to create page: 0.361 seconds
