Oil change(s)....
  • Back in Black
16 Oct 2011 13:51 #23765 by Back in Black
Oil change(s).... was created by Back in Black
I have just changed the engine, gearbox, transfer box and diffs oil, and as my 11 year old daughter would say OMG!!
What a difference fresh oil makes!! It's like a new car. Spark plugs next.....
Not all good news though, whilst struggling about underneath I noticed I definitely need a new back box and quite a bit of Wagtail damage to various dangling down bits. Need some protection down below (oh err). Also must sort the rear towing things - one took a beating/bending at wagtail. Need a proper tow/recovery bar.
  • doncarlyon
16 Oct 2011 14:06 #23766 by doncarlyon
Replied by doncarlyon on topic Re: Oil change(s)....
My mate knocked up a couple of rear recovery points that clamp to the rear chassis leg and they are spot on. Or i think you can buy one in the shop on here.
  • Back in Black
16 Oct 2011 14:21 #23769 by Back in Black
Replied by Back in Black on topic Re: Oil change(s)....
Thanks for that I'll check the shop out.
At wagtail someone had a bar across the rear with D's on either end, which I presume is also attached to the chassis.
  • darthloachie
16 Oct 2011 15:38 - 16 Oct 2011 15:42 #23774 by darthloachie
Replied by darthloachie on topic Re: Oil change(s)....
Back in Black wrote: I have just changed the engine, gearbox, transfer box and diffs oil, and as my 11 year old daughter would say OMG!!
oops sorry :blush: :)
Last edit: 16 Oct 2011 15:42 by darthloachie.
  • darthloachie
16 Oct 2011 15:46 - 16 Oct 2011 15:57 #23775 by darthloachie
Back in Black wrote: Thanks for that I'll check the shop out.
could have been us- it was a towbar with recovery shackles welded on each end
Attachment rear.jpg not found
Last edit: 16 Oct 2011 15:57 by darthloachie.
  • Back in Black
16 Oct 2011 16:25 #23783 by Back in Black
Yep that's the sort of thing, is it attached to the towing points or chassis proper? Ideally I'd like something similar with the D's and a removeable tow hook.
There's no need to say sorry. It wasn't your fault I a) got stuck and b) wasn't prepared AND you did get me out (thank you for that). If I had proper recovery points you'd have had an easier time getting me out.
Time to create page: 0.384 seconds
