shackle question
  • adam
03 Oct 2011 10:19 #22969 by adam
shackle question was created by adam
Hello people,
I have a slightly thick question about shackles on the recovery lugs front and rear.
I bought 4 bow shackles to have permanently attached. the diameter of the pin is 18mm. each shackle is 3.25 tone. The first one (rear near side) went striaght on.
All the rest are slightly too tight. I know if I file the rear off side down it WILL fit but havent yet but the front are quite a way off. to save me buying more of the wrong size can someone tell me where to get the correct size from please! Now my next question is even if I got the front ones to fit, they seem too close to the anti roll bar and im worried even with smaller shackles, they will catch. does this sound normal?
Thanks
Adam
  • goatboy
03 Oct 2011 10:52 #22970 by goatboy
Replied by goatboy on topic Re: shackle question
I had to borrow a shackle at Wagtail and I'm pretty sure it was a 2 tonne one from screwfix.
www.screwfix.com/p/alloy-steel-bow-style...g-shackle-2-0t/59087
But don't take my word for it as I know nothing about shackles.
  • adam
03 Oct 2011 11:25 #22971 by adam
Replied by adam on topic Re: shackle question
Thanks Goatboy, any ideas about the anti roll bar?
03 Oct 2011 11:27 #22972 by mcjimny
Replied by mcjimny on topic Re: shackle question
I've got 3.25t bow shackles for mine. On my front eye though there is the elongated holes but further up there are bigger round holes, i use these but when using a bridle it squashes the black trim in the middle of the bumper.
I'd not bother having them on all the time personally though. a) they will rattle like hell and quickly become annoying b) will get nicked(round some parts near me anyway c) may seize on/up.
I guess you are aiming then when being recovered to attach another shackle to the ones you've left on the car? Best thing imho is to just put a strap and shackles on before you set off as inevitably you will get stuck in the deepest and coldest mud you can find and have to grope around trying to feel around to put the strap on. After i've used mine i give them a good clean and make sure the threads are clean then spray with wd40. Then before any trip where i'll be using them i give them another spray.
Don't forget to back them off when you put them on either.
03 Oct 2011 11:40 - 03 Oct 2011 11:41 #22973 by dirtydogz
Replied by dirtydogz on topic Re: shackle question
The shackle goatboy borrow was one of mine and he right it's was a 2t from screwfix.
Attachment phoca_thumb_l_DSCF1546_2011-10-03.jpg not found
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 03 Oct 2011 11:41 by dirtydogz.
  • adam
03 Oct 2011 11:46 #22974 by adam
mmm interesting, Iv not seen the other holes, Ill have a look later. thanks
Iv just seen the exact ones on ebay and a bit cheeper!
still cofused about the anti roll bar though :s
thanks guys
Time to create page: 2.680 seconds
