smoking Jimny
  • v8dougie
20 Mar 2011 00:15 #13656 by v8dougie
smoking Jimny was created by v8dougie
I have a 2000 Jimny with the G13BB engine, it has done 95k miles with full service history.
Starts and runs fine, pulls happy enough, and no probs at all, however it gives a puff of blue smoke when first started. It does not smoke at all when driving, even when bein pushed, so assume there must be a very minor leak which pools in a cylinder when not in use, any ideas what it could be? Very early signs of head gasket failure? Rocker cover gasket failure or worn piston rings?
Any help greatly received!
  • bryandenham
20 Mar 2011 12:50 #13672 by bryandenham
Replied by bryandenham on topic Re: smoking Jimny
hiya, covered this a few months back in tech.
Came to the conclusion it is valve guide oil seals.
Mine has done 117,000 and does exactly the same, general opinion, just keep truckin'.
Short term cure ?? Just 'blip' the throttle as you turn the ignition off, works on mine, almost no smoke on re-start next morning.
All the best, Bry D.
20 Mar 2011 14:25 #13675 by kirkynut
Replied by kirkynut on topic Re: smoking Jimny
I would say the same. Our old SJ burnt oil all the time and I had it rebuilt but wish I'd taken the advice of my mot tester and left it alone. It never effected the mot and I just topped the oil up every now and then. It's not an issue.
  • v8dougie
20 Mar 2011 22:03 #13721 by v8dougie
Replied by v8dougie on topic Re: smoking Jimny
Thanks for the responses. Just found that thread, sorry for doubling up, did try the search button but not very well apparently!
Bry D - is yours still not smoking 8 months after using that oil stop leak stuff? Or has it started again?
I do not like the idea of starting the car and it puffing out blue smoke, but am loathed to disturb the head as there are no other head gasket problems as yet.
Cheers
21 Mar 2011 05:46 - 21 Mar 2011 05:47 #13722 by facade
Replied by facade on topic Re: smoking Jimny
You can probably change the seals with the head on, with a bit of ingenuity, but probably best not to bother until the oil consumption reaches 1000miles per litre.
Just don't look behind when you start it up :whistle:
Last edit: 21 Mar 2011 05:47 by facade.
  • v8dougie
19 Sep 2011 17:38 #22143 by v8dougie
Sorry to reactivate this oldish thread, but have noticed something unusual!
Could anyone explain why, when I park my Jimny pointing slightly down hill overnight, it does not smoke on start up. If I park uphill, then it is quite a sizeable cloud of blue smoke!
A logical explanation anywhere?!:(
Time to create page: 0.171 seconds
