Tires
  • Ausjimny
09 Feb 2011 08:09 #11214 by Ausjimny
Tires was created by Ausjimny
Hey guys
you have probably had this question a thousand times, but i have just had a 2 inch spring lift put in the jimny ( It raised it a bit more than that though because i got heavy duty coils and the old suspension had sagged with age) and i was first of all wondering if 235/75/15 ' s were possible to fit without cutting, or if 215/75/15 were the bigest i could get. Also does the engine struggle a bit with the bigger tyres?
  • biggaz
09 Feb 2011 09:18 - 09 Feb 2011 09:18 #11215 by biggaz
Replied by biggaz on topic Re: Tires
Yes engine will struggle, quite a bit with the 235's and a little bit with 215's.
Id say without cutting, the 215's will be perfecty fine but 235's normally need some trimming of bumper egde and arch's.
Mine is on 215/75 bfg mud.
Last edit: 09 Feb 2011 09:18 by biggaz.
  • a18suf
09 Feb 2011 09:46 #11217 by a18suf
Replied by a18suf on topic Re: Tires
ive got a 2" lift and have 225/75/16 the arches did need cutting and it does struggle gaining speed.
  • Monkey
09 Feb 2011 09:47 - 09 Feb 2011 12:12 #11218 by Monkey
Replied by Monkey on topic Re: Tires
I'm running 235's mt's on my jimny, yes there will be a power loss but nothing prober gearing won't fix.
You can get 235's under a jimny with a 2" lift providing you don't have to much off-set on your rims and you will need to trim up the front bumper.
Last edit: 09 Feb 2011 12:12 by Monkey.
  • Ausjimny
09 Feb 2011 12:24 #11237 by Ausjimny
Replied by Ausjimny on topic Re: Tires
cheers guys looks like ill have to go with the 215's, just because i dont trust my self to cut haha
  • Gromit
09 Feb 2011 18:38 #11253 by Gromit
Replied by Gromit on topic Re: Tires
I have a 3" lift on mine but I still had to cut the arches to get the 235/75's on. I find that the higher gearing is only really noticeable against a head wind on the motorway.
Time to create page: 0.367 seconds
