Re:The Rat Trap
02 Apr 2019 16:05 - 02 Apr 2019 16:06 #205409 by yakuza
Replied by yakuza on topic The Rat Trap
Keirravn wrote: Cheeky update -
Had a last ditch attempt at sorting the dead OBD2 port today. Long story short I succeeded! But I think I've killed my instrument cluster in the process.
I took the cluster out to recheck my connections. Managed to short something in the process. Lost all of the 'delayed' warning lights other than airbags (EML etc).
Found a popped fuse whilst trying to get them back and my OBD2 came back to life! Interestingly I had previously checked the fuses and not found an issue. Maybe a poor connection of some sort but whatever - replacing it brought the port back to life.
A scan with what I have shows no faults so I'm wondering if it was on due to the fuse. Cleared it anyway. Annoyingly though I now can't tell if the light would be off or not ....
For now I've made a magical secret emergency repair which may assist with the MOT assuming it passes emissions. Then I'll replace the cluster and hope all the lights come back no issue.
Fingers crossed - I'll know more tomorrow
I too lost the warning light delay, probably after fiddling with the ODB port. However mine stayed on.The brake warning light never shut off.
changing the cluster fixed it. It will change your milage.
Last edit: 02 Apr 2019 16:06 by yakuza.
The following user(s) said Thank You: Keirravn
  • Keirravn
02 Apr 2019 17:28 #205420 by Keirravn
Replied by Keirravn on topic Re:The Rat Trap
Appreciate the input mate cheers :) the cars only done 66k so it's a shame but I can live with it. I was worried changing the cluster wouldn't sort it so happy to hear it most probably will
  • Keirravn
02 Apr 2019 17:29 - 02 Apr 2019 18:25 #205421 by Keirravn
First drive (other than a wee test when buying) today and happy to find no crazy noises, overheating or death wobble!
Painfully slow right enough. But goes well. MOT Thursday morning :)
Last edit: 02 Apr 2019 18:25 by Keirravn.
  • Keirravn
04 Apr 2019 12:13 #205532 by Keirravn
Mot verdict - needs brake pipes as expected. Also barely any handbrake on one side,hopefully just requires adjustment. Horn not working (forgot to check that).
Couple of wee advisories which I'll sort after.
So quite pleased really :) likely be on the road next week
05 Apr 2019 05:47 #205558 by Lambert
Replied by Lambert on topic Re:The Rat Trap
Excellent news. Did you make sure that the tester knew that the pipes on the front axle are vacuum and n9t brakes? I have had to bring it up on 2 tests now.
  • Keirravn
05 Apr 2019 17:54 - 05 Apr 2019 17:54 #205575 by Keirravn
Replied by Keirravn on topic The Rat Trap
Lambert wrote: Excellent news. Did you make sure that the tester knew that the pipes on the front axle are vacuum and n9t brakes? I have had to bring it up on 2 tests now.
I was present for the test and he spotted them mentioned it then caught himself. A lesser experienced tester wouldn't have known though!
The fronts are all good. The rears are rotten
Last edit: 05 Apr 2019 17:54 by Keirravn.
Time to create page: 2.158 seconds
