02 Nov 2017 18:08 #185756 by Riccy
That looks to have the making of a bargain lift kit ;-) What shocks are you using to go with the +4" springs? I have in my mind ive seen procomp on there? Im looking at what to do for these Zanfi springs TomDK is tempting me with :-)
Also do you have any issues with the rear shock rubbing on the panhard rod bracket (driver side i think)? Mines started with it since changing the arms to KAP corrected ones ;-(
The topic has been locked.
02 Nov 2017 21:18 #185770 by X8GGY
I had AVO shocks front and rear, but bent the rears when the radius arm / axle holes ovaled and the axle rotated and killed the rear shocks :( , so I've got AVOs on the front and ProComps on the rear...
03 Nov 2017 06:26 #185778 by Lambert
Are the avo ones adjustable for compression and rebound or just rebound?
03 Nov 2017 06:41 #185779 by X8GGY
03 Nov 2017 06:56 #185781 by Lambert
Ok cheers.
14 Nov 2017 15:07 - 14 Nov 2017 15:08 #186235 by X8GGY
Little bit of TLC before Sunday's upcoming 'laning trip - Oldham to Holmfirth...
My Zanfi panhard bracket had started rocking on it's mount again... there is a fair bit of leverage on it though.
Found the 8mm bolts supplied with it had worked their way loose and were wobbling around in the slightly oversize holes, so I drilled them both out to 10mm and fitted new bolts and nylocs and then reassembled everything with new nylocs on the other bolts too...
And then I cleaned "Buzz" my cordless chainsaw! Not sure if he'll be needed on the run on Sunday, but he rides along in the back just incase... ;)
Last edit: 14 Nov 2017 15:08 by X8GGY.
Time to create page: 2.574 seconds
