BigJimnyMeet 2024
4wd low and high panel bulbs
- Visitor
31 Jan 2020 16:39 #217903
4wd low and high panel bulbs was created by Daniel30
Evening all, has anyone got a link to the bulbs for the 2wd, 4wd high low panel and my heater temperature dial looks dull to are these the same bulbs?
- gusthegorilla
- Thank you received: 190
31 Jan 2020 17:19 #217905
by gusthegorilla
I'm planning to live forever.....so far, so good !!
Replied by gusthegorilla on topic 4wd low and high panel bulbs
Convert it to a stick box and you won't need those bulbs....!!!!!!!!!
- Visitor
31 Jan 2020 17:28 #217906
Replied by Daniel30 on topic 4wd low and high panel bulbs
I'll tell you where to stick it in a minute
- Max Headroom
- Banned
- Thank you received: 217
01 Feb 2020 05:09 - 01 Feb 2020 05:10 #217919
by Max Headroom
Replied by Max Headroom on topic 4wd low and high panel bulbs
Not sure where I got this from, but I was under the impression the 'bulbs' on the 2wd/4wd/Hi/Low are soldered onto a circuit board
Last edit: 01 Feb 2020 05:10 by Max Headroom.
- Visitor
01 Feb 2020 12:50 #217924
- Max Headroom
- Banned
01 Feb 2020 13:57 - 01 Feb 2020 14:08 #217925
by Max Headroom
Ah well done! And thank you for dispelling the impression I was under ! ...But what kind of bulb is it?
Last edit: 01 Feb 2020 14:08 by Max Headroom.
- Visitor
01 Feb 2020 15:11 #217926
- theoldseacaptain
- Junior Member
- Thank you received: 7
01 Feb 2020 15:52 #217927
by theoldseacaptain
Sadly jimny-less but still got the bug!
Replied by theoldseacaptain on topic 4wd low and high panel bulbs
I changed one on mine - trying to find the receipt! Got the bulb online and think it was a German website.
The following user(s) said Thank You: Daniel30, Max Headroom
- Max Headroom
- Banned
01 Feb 2020 22:18 - 01 Feb 2020 23:00 #217952
by Max Headroom
Thanks Cap'n
It looks almost like an LED. How did you remove it Dan - does it simply unscrew off the board?
EDIT:
OK I found this VIDEO LINK
From that, I fathomed these are probably T1 12v 60ma Wire Ended micro bulbs
They're available HERE or probably from the usual suspects such as eBay
EDIT:
Last edit: 01 Feb 2020 23:00 by Max Headroom.
The following user(s) said Thank You: IzakJackson
- Visitor
02 Feb 2020 00:24 #217956
That looks like the ticket thank you very much
- Max Headroom
- Banned
02 Feb 2020 07:42 #217962
by Max Headroom
You're more than welcome!
I've got one gone out on mine but I thought they were soldered onto a board for some reason so left it alone ...until now!
- Visitor
02 Feb 2020 11:24 #217973
When I get the bulbs and fit them if everything works ill send you some if that's all you need, I have got a few variations coming now so I will see which one is the best, I have sourced aone with a holder attached but will have to see if they fit in and lock in the panel
Time to create page: 0.160 seconds
