BigJimnyMeet 2024
Re:Front Fog Lights
- Michael01474
- Visitor
03 Mar 2017 15:41 #178778
by Michael01474
Front Fog Lights was created by Michael01474
My brother-in-law has an 03 plate Jimny that he desperately wants to fit front fog lights to.
He's finding it to get hold of some OEM spotlights so I was hoping someone here may have some advice on which aftermarket one's would do the job.
I've not had a chance to have a look to see if any of the wiring is in place but any info/help, including with fitting would be gratefully received.
Thanks in advance
Michael
Thanks in advance
Michael
- Thank you received: 252
03 Mar 2017 15:53 #178779
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Front Fog Lights
I have a set of genuine fog lights for sale including the wiring and switch. £50
Grey pick up Jimny
- Michael01474
- Visitor
03 Mar 2017 16:05 #178780
by Michael01474
Replied by Michael01474 on topic Front Fog Lights
Thanks for the reply. What year are they from? I'm not fully clued up about the differences in bumper/fitment. Do you have any pics?
Thanks
Michael
Thanks
Michael
- Michael01474
- Visitor
03 Mar 2017 16:19 #178781
by Michael01474
Actually, if they'll fit an 03 I'll take them. I think my BIL nearly passed out when I said I'd found some genuine one's. How do we proceed from here?
Thanks
Thanks
03 Mar 2017 16:27 #178782
by j999pre
Grey pick up Jimny
Hi Michael. They are from a 2002. They will fit the 2003.
Send me a pm with your email or mobile and I'll send some pictures.
Cheers
Cheers
Grey pick up Jimny
The following user(s) said Thank You: Michael01474
- Michael01474
- Visitor
03 Mar 2017 17:09 #178783
by Michael01474
Message sent.
Thanks
Thanks
06 Mar 2017 14:33 #178876
by Bosanek
Replied by Bosanek on topic Front Fog Lights
As far as I know, the fog lamps themselves and the wiring should be the same for any Jimny (1998-2017).
It's the fog lamp brackets (mounts behind the front bumper) which differ according to front bumper generation.
So, just obtain the fog lamps together with the wiring and the brackets from a Jimny which has/had the same bumper model as yours.
- Michael01474
- Visitor
09 Mar 2017 06:24 #178999
by Michael01474
Ok, so I now have a set of OEM fog lights thanks to James. The engine bay wiring seems pretty simple but I need a bit of help with the switch wiring. I understand where the pink wire with the bullet connector needs to plug in but what do the blue, brown and black wires connect to. Any help appreciated.
- Thank you received: 332
09 Mar 2017 09:23 #179000
Replied by yakuza on topic Front Fog Lights
My 2005 jimny had all the wiring needed, i found the connectors behind the headlights. Only needed the metal brackets inside front bumper and the switch and of course the lamps. i bought the cheapest lamps i could find on ebay and they are really bad. horrible.
Brackets bought from the Suzuki dealer, original. Not too expensive.
11 Mar 2017 17:06 #179077
by Casey
Replied by Casey on topic Front Fog Lights
Take the live off the headlight so the fog's only come on when headlights are on. Run it through a fuse and a relay and run negative to earthing point on the body behind battery. Connect the switch to the relay.
Type wiring fog lights into Google and you'll find some diagrams.
11 Mar 2017 17:09 #179078
by j999pre
Grey pick up Jimny
I'll look in mine in a minute. I'll let you know
Grey pick up Jimny
11 Mar 2017 17:25 #179080
by j999pre
Grey pick up Jimny
Ok. In mine the blue and the brown from the switch go to the red with a yellow stripe. The black is earthed. The bullet goes to the female bullet hanging out of the fire wall grommet on the inside.
Grey pick up Jimny
Time to create page: 0.127 seconds
