Steel vs Alloy wheels
- BigMat
- Visitor
- Thank you received: 153
- little jimny
- Visitor
and prettier but more expensivesupergaz wrote: ...Alloys are lighter and weaker.
- BigMat
- Visitor
- Thank you received: 28
Width
Diameter
Offset
What tyre size you plan to use
weight
off road use
build quality
IMO Alloy is not always lighter than steel. Our Jimny's are very finely tuned vehicles and heavier wheel/tyre combination can makes big difference to MPG and the dreaded death wobble.
I have 3 sets of wheels and tyres and would say that the standard steel wheels are the lightest I have. Fitted with a good 195 80 15 Mud tyre and a set of wheel spacers will probably give the best performance for less cash outlay. If you damage one, they are cheap to replace.
The aftermarket steel modulas ( Modular Wheels ) are a nice wheel for the Jimny and have the right offset and width for the Jimny, but are a bit heavier. If you are not bothered about less MPG. this would be a good cheap option that does not need spacers.
Black Modular 7 x 15s
If money is no object checkout the Mach 5 wheels - Mach5 Wheels
Back to your question. I think it depends on what is important to you - strength; looks or value for money.
Alloys certainly can be easy to damage and then the paint or finish deteriorates. Some alloys become porous after a period of time. Steel wheels can easily be painted if damaged.
Hope the above is helpful.
Cheers
paul
Hertford
2005 Jimny VVT soft top
2002 Jimny Soft top - Sold
2007 Triumph Tiger 1050 - Sold
2011 Kawasaki W800
2002 Twin boys
2001 Kerry Blue Terrier - RIP
2012 GoldenDoodle
- vitara_mad
- Visitor
Mine were cheap too. brought new from the importer in Maldon
Cheers
paul
2011 Kawasaki W800
2002 Twin boys
2012 GoldenDoodle
- Thank you received: 584
(The tree huggers have stopped us using proper chromate primer on alloy, so the paint flakes off, corrosion builds between tyre and rim, which is porous, and the tyre goes down.)
Stick to steel if you can get them.
- BigMat
- Visitor
- TomDK
- Visitor
BigMat wrote: Cheers for the replies guys very interesting and informative next question if you were going to fit a 235 or above tyre on the rim would you go for a seven or eight inch wide wheel??
I have 235s on standard Jimmy alloys. They're 5,5" or 6" wide.. No problems with that
- Jimny J
- Visitor
