Slight lean to the right on my gen 4?
- AlexK
- Visitor
Andy2640 wrote: Any other gen 4 owners got the same lean or ??
I have a feeling mine does this too, but I haven't looked at it closely. Next time it's on level ground I'll try and measure it.
- Thank you received: 552
mlines wrote: Gen3 had different rate springs on the rear to compensate. It sags after a while.
That's what I had seen, the drives side rear spring (as supplied by Suzuki) is slightly longer on a G3, I believe to compensate for the driver. This rings true of my own standard 2009 which is 10mm higher on the drivers side rear compared to passenger, almost level with driver onboard.
Not sure aftermarket springs do the same, hence they can induce a lean. Can't say I've had an issue so far with sagging standard springs and the Jimny's getting on a bit, but it could happen.
My Land Rover Series 2 has different rate "cart springs" on the rear, the drivers side more curved than the passenger, again to compensate for driver load, that's why I think your Jimnys leaning the wrong way.
Sorry it's not G4 specific, but you would have thought this was a carry over from the G3 as the underpinnings are very similar.
Sorry not much help, you could ask Suzuki what's going on, it's still under warranty.
- Andy2640
- Visitor
Riccy wrote: What shape is the fuel tank and how full was it? On a gen3 the tank is larger on the passenger side than the driver. Doubt it makes that much difference, but who knows?!
Running on fumes unfortunately Riccy. Like below 20 miles. Canny be that either. Hmmmmm! Scratch noggin.
- Thank you received: 320
- Andy2640
- Visitor
Gadget wrote: I'm not even going to look at mine, as I'll get all OCD if I spot a hint of lean!
Lol
Your jim, is whispering .... "Pssst... psst ....... Gadget....come check my lean". But whatever you do, dont give in and check
Tick tock ... tick tock!!
- Aj4x4
- Visitor
- Andy2640
- Visitor
Aj4x4 wrote: I haven't checked mine yet. Problem is that as it's so damn good looking it's only a matter of time before I look back after parking up and seeing a lean..... or just have a paranoid feeling lol.
I"m always looking at mine. Just never gets old. Everytime i go out, i look forward to the drive. Its a real love affair. Corny but true.
I just wish more accessories would come out. I really want a quality bull bar. But all the ones available at the minute are a vit naff. Most hang down belkw the bumper, massively deceeasing approach angle. Oh and a snorkle would be great.
Anyways......
- Thank you received: 584
I don't worry about it, I can't tell when I'm sitting in it.
- Thank you received: 1761
