what engine to fit to jimny ?
- whittleos
- Visitor
im going to be doing the t-case transfer box change soon once iv worked out engine .. i know the vit use the 1.9 dt engine from a 306 would the jimny gear box bolt onto that with out mods ? any help would be great thank you all ..
- ne-crock
- Visitor
- Thank you received: 153
- whittleos
- Visitor
- Smoggy
- Visitor
pm me if you need more details.
- GuardianAngel
- Visitor
Smoggy wrote: You cant put a vvti engine into your non vvti car. Its a disaster believe me I learned from bitter 1st hand experience at the hands of some right monkeys
Out of interest, why?
- steffan
- Visitor
What ever came of that smoggy did you get sorted in the end up or you still having trouble with itSmoggy wrote: You cant put a vvti engine into your non vvti car. Its a disaster believe me I learned from bitter 1st hand experience at the hands of some right monkeys
- whittleos
- Visitor
- whittleos
- Visitor
I've been thinking an early MX5 engine might be a good swap. They are the same RWD layout, fairly light-weight and with lots of aftermarket solutions for engine management.
Keeping with the Suzuki engine, they seem to have a lot in common with the bigger engines in the Swift and Liana. One australian member on here has fitted a 1.8 from a Liana, although I don't think that engine was available in the UK. The bore is the same on the 1.3 as on some of the 1.6s, so it may be that you could swap the crank and rods but keep everything else stock. That sounds far too simple to work, though.
A few people have done diesel conversions. I can't see the diesel route making much sense for road use. The slower revving engine won't work with the Jimny gearing, and too much torque is just gonna end up breaking things. An equivalent diesel engine will also be more complicated and heavier.
- gaz3359
- Visitor
- whittleos
- Visitor
