BigJimnyMeet 2024
× A place for general chat about the Jimny. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
12v/24v winch wiring
  • oxford_bloke
  • Visitor
  • Visitor
28 Apr 2012 19:19 #38794 by oxford_bloke
12v/24v winch wiring was created by oxford_bloke
guys,
I want to run 2 x 12v winches, with 24v to each one for faster does anybody have a wiring diagram or the knowledge of how to do this?
cheers
  • Blakey
  • Visitor
  • Visitor
28 Apr 2012 19:32 - 28 Apr 2012 19:33 #38795 by Blakey
Replied by Blakey on topic Re: 12v/24v winch wiring
You can get the converter from goodwinch that does it think its about £200. I have gone down the route of having a 24v alternator and two batteries for my winch then running the standard alternator for the ingnition sysytem.
Last edit: 28 Apr 2012 19:33 by Blakey.
  • TomDK
  • Visitor
  • Visitor
28 Apr 2012 19:36 #38797 by TomDK
Replied by TomDK on topic Re: 12v/24v winch wiring
oxford_bloke wrote: guys,
cheers
What winch do you have? Is it up to the 24 volts?
  • oxford_bloke
  • Visitor
  • Visitor
28 Apr 2012 19:41 #38798 by oxford_bloke
Replied by oxford_bloke on topic Re: 12v/24v winch wiring
I have done a bit of research and chatting to friends, Running a 12v winch of of 24v reduces the amount of current drawn however burns the motors out quicker (approx 2 years heavy winching)
how did you fit a 24v alternator? any pics? my ideal would be to use the standard alternator but i think it isn't man enough
cheers
  • Blakey
  • Visitor
  • Visitor
28 Apr 2012 19:48 #38799 by Blakey
The alternator is off a toyota coaster its the same setup as rob at ORA had on his Jimny. It fits with a tiny bit of fabrication to the brackets. Not got the Jimny to take any pictures as it is at ORA having some work done. When i was building the truck i was looking at going 12v but changed my mind but i went to the local car electrics place and told the chap i was after a bigger output alternator and he listed loads that would fit in the space of the standard one that would be man enough to run one of the goodwinch boxes.
  • oxford_bloke
  • Visitor
  • Visitor
28 Apr 2012 19:54 - 28 Apr 2012 19:56 #38800 by oxford_bloke
is there a way round buying the converter? I have a friend that has done it but he is in the navy and away for a few months!
another question what batteries have you fitted? was looking at the Numax CXV-X but got a feeling i might struggle to get 2 under the bonnet
Last edit: 28 Apr 2012 19:56 by oxford_bloke.
  • Blakey
  • Visitor
  • Visitor
28 Apr 2012 20:16 #38804 by Blakey
i am running two Odyssey PC1500 for the winch but mine is traybacked so not got the issue with space. May be able to get two under the bonnet if you could move some bits about and fab up a cradle over the other wheel arch.
Mines done as i have got the two alternators. The only way round buying the convertor i think is to run a 24v alternator back to two 12v batteries in series to give you the 24v.
  • oxford_bloke
  • Visitor
  • Visitor
28 Apr 2012 20:26 #38805 by oxford_bloke
its all food for thought at the moment do you need a converter for each winch?
  • Blakey
  • Visitor
  • Visitor
28 Apr 2012 20:37 #38806 by Blakey
only need the one convertor
  • TomDK
  • Visitor
  • Visitor
28 Apr 2012 21:50 #38811 by TomDK
oxford_bloke wrote: its all food for thought at the moment do you need a converter for each winch?
Are you sure your winch motor can take 24 volts? Not all can.
  • oxford_bloke
  • Visitor
  • Visitor
28 Apr 2012 21:58 #38813 by oxford_bloke
only got one at the moment it is a kingone 9.5c (same as goodwinch and superwinch) fitted with a bow motor 2
  • oxford_bloke
  • Visitor
  • Visitor
28 Apr 2012 22:14 - 28 Apr 2012 22:14 #38816 by oxford_bloke
found the diagram this will save loads of money
forum.difflock.com/viewtopic.php?t=46157
Last edit: 28 Apr 2012 22:14 by oxford_bloke.
Time to create page: 0.122 seconds
Powered by Kunena Forum
