BigJimnyMeet 2024
Jimny from Cape Town, South Africa
- LuckyStriker
- Visitor
04 Feb 2011 13:15 - 07 Feb 2011 05:36 #10920
by LuckyStriker
Jimny from Cape Town, South Africa was created by LuckyStriker
Hi there
Just thought I'd say hello and show pics of my Jimny, a work in progress
So far I have installed Old Man Emu suspension, 215/75 All-Terrains, 2.7ton winch, shovel on the back (unused), and various bits and pieces not so noticeable by the casual eye.
Looking forward to sharing some of my other mods and asking some advice on how to make my Jimny a bit more extreme
Cheers
The day I picked it up at the dealers. Looking very effeminate, oh dear. We shall have to do something about that.
Cheers
Last edit: 07 Feb 2011 05:36 by LuckyStriker. Reason: Replaced attachments with links
- biggaz
- Visitor
04 Feb 2011 13:43 #10924
by biggaz
Replied by biggaz on topic Re: Jimny from Cape Town, South Africa
Hi and welcome, nice Jimny you have!
Love the winch looks very well fitted, discreet!
- dave t
- Visitor
04 Feb 2011 13:50 - 04 Feb 2011 13:51 #10926
by dave t
Replied by dave t on topic Re: Jimny from Cape Town, South Africa
hi and welcome nice jimmy, as gazza says the winch is a cracking job, just going to fit one in mine its the next thing on the list.
Last edit: 04 Feb 2011 13:51 by dave t.
- zukhunter
- Visitor
04 Feb 2011 14:35 #10930
by zukhunter
Replied by zukhunter on topic Re: Jimny from Cape Town, South Africa
hi and welcome to the forum
- Strek
- Visitor
04 Feb 2011 14:57 #10932
by Strek
Replied by Strek on topic Re: Jimny from Cape Town, South Africa
Nice one.
Do you have any pics of those d-ring shackle mountings? Looks great. I'm currently making d-ring shacklemount at the rear, and would def like some up front as well. Bolted or welded to the frame?
- darthloachie
- Visitor
04 Feb 2011 15:37 #10936
by darthloachie
Replied by darthloachie on topic Re: Jimny from Cape Town, South Africa
love the skull & crossbones
- biggaz
- Visitor
04 Feb 2011 15:41 #10938
by biggaz
yeh im interested in those front recovery points aswell
- renard38
- Visitor
04 Feb 2011 17:23 #10945
by renard38
Replied by renard38 on topic Re: Jimny from Cape Town, South Africa
hi
good pictures
good pictures
- vitara_mad
- Visitor
04 Feb 2011 17:42 #10950
by vitara_mad
Replied by vitara_mad on topic Re: Jimny from Cape Town, South Africa
nice jimny you got there but i think your camber is a bit out in the first pic
- LuckyStriker
- Visitor
07 Feb 2011 05:24 #11145
by LuckyStriker
Replied by LuckyStriker on topic Re: Jimny from Cape Town, South Africa
Thanks for the warm welcome everyone. much appreciated.
Here are some step-by-step photos of the winch installation plus the recovery points and shackles.
Standard front
Bumper removed. The winch will sit between the two beams of the ladder chassis
To save time and money, I did all the pre-weld preparations myself, such as cleaning off the paint
I bought two-ton shackles and had some lugs fabricated. The standard towing ring on the Jimny doesn't look tough enough for a recovery point
I designed the plate on which the winch will sit and had it cut at a friend who owns a waterjet company. 6mm high tensile plate steel
There we go, the plate and the recovery points are welded on. The plate does not extend past the chassis but the lugs do. Hopefully this won't affect my approach angle too much.
This is the winch that I went for.
The Jimny has a gross weight of 1,4tons and a dry weight a bit below 1ton. According to my calculations a winch with a pulling power of 2tons would therefore be the minimum requirement (the absolute minimum).
This T-max pulls 2.2tons which will hopefully be enough.
But the advantage of the winch is that it is REALLY compact and quite light. At 20kg it doesn't push down the front suspension by more than 5mm.
Then came the tricky part. Refitting the bumper and cutting holes in all the right places.
I didn't want to butcher my car so I had to keep the cutting as minor as possible.
My considerations were that the winch should never make direct contact with the plastics (apparently can get pretty hot) and that there should be some space to get my hand in so that I can engage the clutch)
The roller protrudes about 1.5cm beyond the bumper, which allows me to run the cable at extreme angles without cutting up the plastic bumper. But I don't want it sticking out so far that it digs into the ground when I go through a ditch.
The winch itself does not block airflow. The radiator and fan is well above the cable drum.
The winch's controller unit is inside the engine bay.
Standard front
08 Feb 2011 13:56 #11185
by saxj
Replied by saxj on topic Re: Jimny from Cape Town, South Africa
Have you managed to use it yet except for the one occassion on your holiday?
Vic
Vic
08 Feb 2011 17:14 #11186
by mcjimny
Replied by mcjimny on topic Re: Jimny from Cape Town, South Africa
I like that a lot, nice and discrete.
Time to create page: 0.142 seconds
