BigJimnyMeet 2024
immobiliser or ECU for not starting
- greenmachine
- Senior Member
- Thank you received: 5
24 Feb 2024 17:58 #254552
by greenmachine
immobiliser or ECU for not starting was created by greenmachine
Now then all, i recharged the battery and turned her over, heres some history 1st, In her past life i swapped the 1.3 M13A engine VVT (55 reg)
for a 1.6 suzuki swift engine, she ran but was lumpy and missing a bit. now after tracking her down and buying he back she will turn over but wont start and squirts fuel out an injector or the rail. she has the engine light on and another light of a car with a padlock through it, pic attached. i,m thinking thats the immoblisler warning light. so to get her going i need to ask a few questions to narrow it down.
1/ do i need to swap the immobiliser out or the ECU or both?
2/ i have a donor jimny 2001 but its not the VVT engine so am i right in thinking that the ECU and IMOB from that wont work? and its scrap/parts
3/ shall i buy more 1.6 or 1.3 injectors and install those?
I,m completley stuck and i,m starting to think this might be impossible or can someone shed light on where i should begin ?
cheers L.
cheers L.
- Thank you received: 653
24 Feb 2024 18:36 #254555
Replied by jackonlyjack on topic immobiliser or ECU for not starting
Here's the part numbers for injector seals
Take no notice that they're motorbike parts
Ebay will be the cheapest
- greenmachine
- Senior Member
24 Feb 2024 18:41 #254556
by greenmachine
Replied by greenmachine on topic immobiliser or ECU for not starting
mega thanks jack, i,ll look into that, cheers.
24 Feb 2024 18:44 - 24 Feb 2024 18:51 #254557
It will make little difference with 13 or 16 injectors both will be fine
I would say get a good second hand ecu with keys ect
seen them sell for around 80 quid
You will need vvt ecu
Have you had obd reader plugged in to see if it tells you anything
Last edit: 24 Feb 2024 18:51 by jackonlyjack.
- Thank you received: 333
25 Feb 2024 06:55 #254564
Replied by yakuza on topic immobiliser or ECU for not starting
If the immo light blink fast there is a problem, if it just lights up steady it is a self test.
Are you sure there is an ecu problem?
Could just as well be the position of the cam sensor ring, coil pack, is there a fuel rail pressure sensor?
- Thank you received: 372
25 Feb 2024 10:06 #254567
Replied by DrRobin on topic immobiliser or ECU for not starting
According to the wiki the immobiliser disables the injectors and the spark.
www.bigjimny.com/mediawiki/index.php/Key...%20unit.&text=4.,ECU.
If you have fuel coming out of the injectors and a spark then it possibly isn’t the immobiliser or the ecu.
Robin
Robin
- greenmachine
- Senior Member
25 Feb 2024 20:10 - 26 Feb 2024 07:13 #254583
by greenmachine
Hey Jack brill thx, ill get some O rings and stop that leaky injector, then get a diagnostics bod to read the faults. the IMMOB light flashes , i remember now cos it was a difficult trying to take a pic of it !! will my ECU and IMMOB of seen better days completely then? ive seen on tebay the steering column, stalks, keys, readers and ecu etc as a pack should i buy all that and fit it?
Last edit: 26 Feb 2024 07:13 by Lambert. Reason: Swearing. Please remember this is a family friendly forum.
- greenmachine
- Senior Member
25 Feb 2024 20:16 #254584
by greenmachine
Hello again Yakuza, we spoke in her previous life when i was swapping the engines i think mate! aye shes flashing sharpish like. U rekon needs plugging in to read faults to see where i,m at, ?
- greenmachine
- Senior Member
25 Feb 2024 20:20 #254585
by greenmachine
Thanks Doc, thats a good point and info i wouldnt of found that, top man cheers.
when the key is in position before turn over it must prime or something as thats when its squirting fuel.
25 Feb 2024 22:24 #254589
It might well run the fuel pump and prime the system, but then not fire the injectors or fire a spark if the immobiliser is still inhibiting the running.
The immobiliser could inhibit either spark or injector (or both) but either spark or injector would stop the engine from starting.
Spark would be the easiest to check for.
If the injectors were firing you would smell fuel if you take the plugs out.
Robin
Robin
26 Feb 2024 07:06 - 26 Feb 2024 07:12 #254593
i got this programmer that I can hook up to the OBD I bought of ebay that can read the immobilizer key chip into the ECU. i had a period of trouble earlier with released smoke from the dash cluster, and druing that time the chips got lost from the ECU from time to time and had to be reprogrammed for some reason.
Also the different ECU series only work with some series of immo chips so not all (hardly any) can be programmed into your ECU I found out. at least not with the cheap ebay tool.
I would try the original parts that came with the car first at least and try to get them to work together.
But most likely if anything is broken to get a full set of immo chip keys, stalk, column, ecu and all as you say.
Some say the immo unit is only a signal amplifier / converter for the ECU and not a stand alone unit (but can still be broken) and from my experience the dash cluster also has a "brain".
Last edit: 26 Feb 2024 07:12 by yakuza.
- greenmachine
- Senior Member
03 Mar 2024 19:43 #254778
by greenmachine
moving in the right direction now, i swapped o rings from my donor jims injector and all spot on now no leaks. now i need a test connected up to the ODB socket. ive sussed all the plug n play immob ecu etc, so will prob scource a 2nd kit on ebay.
